Turbo with ITB?
Old Nov 30, 2003 | 12:03 AM
trbcivic's Avatar
Default Turbo with ITB?
Is anyone using ITB with turbos?
How hard it it to tune?
Old Nov 30, 2003 | 12:31 AM
MiraiZ's Avatar
Default Re: Turbo with ITB? (trbcivic)
That would be a really unusual set up...what would the intake pipe look like?
Old Nov 30, 2003 | 12:41 AM
liam821's Avatar
25 Year Member
I suppose you could do it...just put the ITB's inside of a huge plenum. There is a few stock cars that do something like this.
liam
Old Nov 30, 2003 | 07:58 AM
hulkhb's Avatar
Default Re: Turbo with ITB? (liam821)
have fun tunning
Old Nov 30, 2003 | 08:21 AM
meanEG's Avatar
Default Re: Turbo with ITB? (hulkhb)
**** that way too inlvolved. you can buy another manifold and have a **** oad left for other stuff. it is hard to tune for NA let alone foro fi.
Old Nov 30, 2003 | 08:37 AM
stierhund's Avatar
you could just split a 2 inch charge pipe into 4 very evenly, would be hard to do if u wanted to use aluminum... but it would still retain the benefit of evenly splitting the airflow
Old Nov 30, 2003 | 08:40 AM
falcongsr's Avatar
What is this crap?
hey! thats a pretty bad idea!
Old Nov 30, 2003 | 09:27 AM
RenoRacing's Avatar
Default Re: (falconGSR)
RB26Dett's(Skyline twin turbo motor) have individual throttle bodies. they just have a large plenum around them to direct the air. I wanna say that they are 40mm I believe. kinda see it in these pics, notice there is no big throttlebody on the plenum.
http://www.rh9.com.au/images/DSC00423.jpg
http://www.rh9.com.au/images/DSC00398.jpg
http://www.rh9.com.au/images/DSC00347.jpg
Old Nov 30, 2003 | 09:52 AM
AlphaKennyWun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
most of the sub 10 sec old skool rx7s and toyotas startlets, corollas do it this way.
Old Dec 1, 2003 | 12:53 AM
trbcivic's Avatar
Liam, I remember you got some ITB from an motorcycle, what do you think of that setup for turbo?
Most of the high out put cars like the GTR, S15 ( I think ) uses ITB turbo set-ups
Thanks
Old Dec 1, 2003 | 06:13 AM
Joseph Davis's Avatar
Tuning ITBs is not hard, you're a bunch of stunnas who can't think out of the box.
You see my pallid scrawny meathook? That's what I think of tuning ITBs.
Old Dec 1, 2003 | 08:44 AM
meanEG's Avatar
Default Re: Turbo with ITB? (J. Davis)
i have mine tuned fine. i mean things like syncing the blades was the hardest part. thats all.
Old Dec 1, 2003 | 10:39 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbcivic &raquo;</TD></TR><TR><TD CLASS="quote">
Im sure it would work. However i dont really know how much better a ITB setup would be from a good sized throttle body and intake manifold. People have made 600whp on a stock b16 intake manifold.
liam
Old Dec 1, 2003 | 10:44 AM
Liam's right.
ITBs are a really nasty NA setup if you can afford the sort of engine that will run them without losing all throttle response. FI + ITBs is just a form of technical engineering masturbation, to prove you can. They are interesting to see, and are interesting to tune, but nothing speshul when the ponies hit the ground.
Old Dec 1, 2003 | 12:09 PM
evoeone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote"> FI + ITBs is just a form of technical engineering masturbation, to prove you can. </TD></TR></TABLE>
HT quote of teh day!!!!
Old Dec 1, 2003 | 01:13 PM
boosted92's Avatar
Liam's right.
I dunno, until we see some back to back results on the same motor we can't tell for sure. But nissan didn't just put ITB's on RB26DETT's and some SR20DET's for ***** and giggles, don't you think?
Old Dec 1, 2003 | 01:22 PM
evoeone's Avatar
Default Re: Turbo with ITB? (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
I dunno, until we see some back to back results on the same motor we can't tell for sure. But nissan didn't just put ITB's on RB26DETT's and some SR20DET's for ***** and giggles, don't you think?</TD></TR></TABLE>i agree but lotta other car companies have done weird htinsg, like VW 20v 1.8T engine uses a MAP and MAF, for ***** and giggles? nope , why i odnt know,
Old Dec 1, 2003 | 01:37 PM
MiraiZ's Avatar
Liam's right.
</TD></TR></TABLE>LOL...nice wording!
Old Dec 1, 2003 | 06:24 PM
danimal's Avatar
my sentiments exactly... bmw has been using itb's for literally decades, going back to the '70's, when it was mechanically injected itb's... nobody knows more about itb's than they do, and they are still putting 'em on their supercars today.
bmw has kicked some major *** in the racing world with itb's.
if there is a problem with throttle response when running itb's, it's usually because they are too big for the application, or they are out of sync... sync'ing 'em is easy, set the blade closing gap relative to the throttle bore before installing on the car, then use a $35 airflow meter to fine-tune.
why would you want 'em on a turbo car? one thing might be superior off-boost throttle response, that you can't get with a plenum-based intake system... don't know that they would make more overall h.p., tho.
craig paisley had a nice set of itb's on his v-8 nitrous motor last year.
Old Dec 1, 2003 | 07:13 PM
Default Re: Turbo with ITB? (danimal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danimal &raquo;</TD></TR><TR><TD CLASS="quote">if there is a problem with throttle response when running itb's, it's usually because they are too big for the application, or they are out of sync... sync'ing 'em is easy, set the blade closing gap relative to the throttle bore before installing on the car, then use a $35 airflow meter to fine-tune.</TD></TR></TABLE>
I use $1.75 homebrew manometer for such things. Mine's more accurate than the last carb synch toolk I purchased, which still languishes in my toolbox to this day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danimal &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want 'em on a turbo car? one thing might be superior off-boost throttle response, that you can't get with a plenum-based intake system.</TD></TR></TABLE>
Just to be an argumentative *****, Nissan gets throttle response by putting tiny *** turbos that spool early onto their engines.
Also, when 25% TP (throttle position) on ITBs ideally sized for NA use nets you more flow than a conventional TB/plenum at 75% TP, I respectfully suggest that the off boost throttle response you are experiencing is the turbo spooling. Only way I can see to sidestep that is to use tiny (by NA ideal) ITBs so the throttle plates act as a restriction to flow at part throttle.
Old Dec 1, 2003 | 08:51 PM
EndlessGarageEG6's Avatar
My friend's ITB TURBO tuned HachiRoku
Old Dec 1, 2003 | 08:58 PM
SiRkid's Avatar
Default Re: Turbo with ITB? (EndlessGarageEG6)
that is one of the hottest corolla's ive ever seen!
awesome!!!!!!!!!!!!!!!!!!
to boost it all you would do it make a small box around the the throttle boddies..so its like making an intake mani with individual throttles inside..
no point like j.davis said...just for "show" really imo even though you cant even see the itb's.
Old Dec 1, 2003 | 09:06 PM
Kwuaymaikrup's Avatar
Default Re: Turbo with ITB? (SiRkid)
That is a badass Corrolla!!!
Old Dec 1, 2003 | 09:09 PM
Dee's Avatar
Dee
Turbo ITB's come stock on Skyline GTR's and Nissan GTiR's. As long as you have a tight seal on the plenum area the setup will perform flawlessly. Longer funnels will be needed to connect the plenum to the ITB's on street-prepped motors.
Old Dec 1, 2003 | 09:26 PM
turbo_ef9's Avatar
Default Re: Turbo with ITB? (Dee)
teamrice.org has some nice cars esp. that corolla... thas my future setup once my friend moves and sells me his AE
