Finally got it done!!!
Old Nov 29, 2003 | 09:18 PM
Alstare's Avatar
Default Finally got it done!!!
After 2 months and millions of dollars later I finally got this POS done and ready to drop back in. I should hopefully have it in tommorow and start breaking it in on monday. Then go tune it in a few weeks and see if I can make some power, just in time for winter.
Big thanks go out to Honda-Tech, Payn Technologies, and JD Performance for there help in finishing this project. :wink:
JDM H22a engine
Darton ductile iron sleeves
Block machined by Golden Eagle
Wiseco Forged 9:1 Coated Pistons
Eagle Mfg. H-Beam connecting rods
Cometic copper custom headgasket
ARP hardend head studs
ARP hardend rod bolts
Hondata Nylon Intake Gasket
AEM EMS standalone engine management
JDM Type-S cams
Place Racing Inc. custom eurathane mounts
Place Racing Inc. custom axles
Dual core aluminum radiator
FAL low profile fan
MSD 6AL Ignition
Accel 8mm wires
Garrett T3/T04e turbo
MaxRev turbo manifold
MaxRev downpipe
Tial 35mm wastegate
Percision 880cc injectors
Spearco 32"x8"x3" FMIC
Greddy Type-S BOV
Greddy EVO catback exhaust system
JD Performance Testpipe
TurboSmart GBCV boost controller
HKS 3" mushroom type air filter
Eliminated balence shafts
JAZ Baffled catch can
ThermoTec header/downpipe wrap
GM 3 Bar Map sensor
EGR bypass plate
H23 Manual Tensioner conversion
Old Nov 29, 2003 | 09:21 PM
B18Flip's Avatar
Default Re: Finally got it done!!! (Alstare)
nice! how much power do you expect from it??
Old Nov 29, 2003 | 09:28 PM
leadfoot78's Avatar
Sounds like you went all out....with the spray can!! Why is the block gold?? And you missed a bunch of spots too. That's a sick H22 nonetheless.
Old Nov 29, 2003 | 09:33 PM
HXMan's Avatar
That is nice. What did payn tech do for you?
Old Nov 29, 2003 | 10:52 PM
Alstare's Avatar
Default Re: Finally got it done!!! (HXMan)
Yes the gold is blinging but it looked better then the pitted aluminum and I got a gold/black theme going on with my car.
I have no ideas for power wise, seems like 350whp is the norm for built h22's we'll have to see. I got 275whp @7.5 psi with the stock bottom end so I hope to improve.
Payn hooked me up with some good deals on parts and a ton of tech info. They did previous tuning, and will be doing my future tuning.
Old Nov 29, 2003 | 11:05 PM
ridnmyhonda's Avatar
Time for new front brakes!
Old Nov 29, 2003 | 11:19 PM
FredoSP's Avatar
very cool!
Old Nov 30, 2003 | 12:09 AM
KStuned's Avatar
Default Re: Finally got it done!!! (FredoSP)
Definitely keep us updated with more PICS and info about the tuning, break-in and so on. Good luck. Have fun.
Old Nov 30, 2003 | 12:39 AM
Kwuaymaikrup's Avatar
Default Re: Finally got it done!!! (Hondaddict)
That gold is hot!!! Good luck with it.
-Ryan
Old Nov 30, 2003 | 12:46 AM
liam821's Avatar
25 Year Member
Default Re: Finally got it done!!! (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">That gold is hot!!! Good luck with it.
-Ryan</TD></TR></TABLE>
Yea thats just bling bling. Im really liking the gold! What car is it going in?
liam
Old Nov 30, 2003 | 01:56 AM
Alstare's Avatar
Default Re: Finally got it done!!! (liam821)
96 civic ex coupe....
same car it was in before, but hopefully it holds together a little better this time.
the car
http://www.activeperf.com/memb...stare
Old Nov 30, 2003 | 02:15 AM
M.A.R.C.'s Avatar
[/Gold Member voice] I LIKE GOOOOOOOOOOOOOOOOOOLD YESH [/Gold Member voice]
Old Nov 30, 2003 | 06:30 AM
SRT-WHORE's Avatar
She is fuggin beautiful. Good lock on the break-in and at the dyno. How much boost you plan on running?
Old Nov 30, 2003 | 08:36 AM
rocket256's Avatar
Hey bro, that is a beaut. Cant wait to see the dyno sheet!!!!
Old Nov 30, 2003 | 08:58 AM
TheShocker's Avatar
Default Re: Finally got it done!!! (rocket256)
Sweet car, sweet set-up...you're going to hit more than 350 WHP...and it's going to be sick.
Old Nov 30, 2003 | 09:38 AM
scrap1ngsr's Avatar
Default Re: Finally got it done!!! (SasquatchMS)
that motor looks very sick
Old Nov 30, 2003 | 10:27 AM
patdemps's Avatar
Default Re: Finally got it done!!! (CivicSiR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiR94 &raquo;</TD></TR><TR><TD CLASS="quote">that motor looks very sick </TD></TR></TABLE>
&lt;---- cant wait to see some numbers
Old Nov 30, 2003 | 10:37 AM
bottlefedb18c1's Avatar
looks nice and with it tunned right you should put down some nice numbers
let us know how you did at the dyno
Old Nov 30, 2003 | 10:51 AM
TheMostSadistic's Avatar
Kind of off topic, but what kind of prep went into painting the block and what kind of paint did you use? Thanks.
Old Nov 30, 2003 | 10:55 AM
Couto's Avatar
Very nice setup something like my futur setup well I will send you an email for more infos if you want ....... Thanks bye
COUTO
Old Nov 30, 2003 | 11:51 AM
booscivic's Avatar
Looks good!!! Good luck!!!!
Old Nov 30, 2003 | 12:57 PM
DLB1994's Avatar
Default Re: (booscivic)
time for a bigger turbo
Old Nov 30, 2003 | 02:53 PM
Default Re: (DLB1994)
bump, need to know about painting it!
Old Nov 30, 2003 | 04:44 PM
Fac3Man's Avatar
Default Re: (TheMostSadistic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMostSadistic &raquo;</TD></TR><TR><TD CLASS="quote">bump, need to know about painting it!</TD></TR></TABLE>
For real, it looks sick man. (&lt;----Once again)
Old Nov 30, 2003 | 04:49 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">time for a bigger turbo </TD></TR></TABLE>
I like the gold block too. I dont know why but I do
