What's stopping you?
Old Nov 29, 2003 | 01:58 AM
Hoosier Daddy's Avatar
Default What's stopping you?
60-0 is important too What kind of brake setup do you have?
Old Nov 29, 2003 | 07:19 AM
SpoolnG2's Avatar
Default Re: What's stopping you? (Hoosier Daddy)
Brembo cross drilled/slotted rotors and aem brake pads. Cant do anything to serious when you gotta run a 13" slick.
Old Nov 29, 2003 | 07:22 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: What's stopping you? (SpoolnG2)
I ran stock gsr brake pads and rotors on my racecar all season. w00t..
Old Nov 29, 2003 | 07:33 AM
BlueSi2k's Avatar
Default Re: What's stopping you? (SIXTYdashONE)
brembro blanks and pepboys ceramic pads. More stopping power than u need for the street.
Old Nov 29, 2003 | 07:37 AM
TurboJesse
Guest
Posts: n/a
Default Re: What's stopping you? (BlueSi2k)
warped and worn stock rotors/pads with over 100,000 miles gets a little scary sometimes, but the look on the passengers face makes it worth it
Old Nov 29, 2003 | 07:44 AM
Bailhatch's Avatar
Default Re: What's stopping you? (Mpir3)
stock with new blanks and AEM/Nissin pads. works pretty well for the $
Old Nov 29, 2003 | 08:57 AM
Phaze2 Mike's Avatar
5 lug for life. Stopped my delsol harder then my s2 does.
Old Nov 29, 2003 | 10:34 AM
T-RO's Avatar
Left Nike out the drivers door...
Old Nov 29, 2003 | 10:45 AM
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">Left Nike out the drivers door... </TD></TR></TABLE>
Old Nov 29, 2003 | 10:50 AM
Foozball26's Avatar
Default Re: (Hoosier Daddy)
the car in front of me
seriously though, stock all the way around. bout to get some ebc green pads just for the extra stopage.
no need for big ole brak rotors.
Old Nov 29, 2003 | 10:54 AM
baphomet's Avatar
Default Re: (Foozball26)
Where do you guys get your brembo blanks from, and what do you pay?
Old Nov 29, 2003 | 11:24 AM
Default Re: (slashDEVslashNULL)
Nice replies guys
Reason I asked is because I don't think my stock CRX SI brakes are gonna cut it. They feel awful, maybe becuase the car has been sitting since August
The pads/rotors were replaced in August though..
Old Nov 29, 2003 | 11:26 AM
TheShocker's Avatar
Stock discs with AEM/Nissin pads and DOT 4 fluid.
Old Nov 29, 2003 | 01:54 PM
raene's Avatar
Integra big-brake conversion.
Hoosier Daddy, do pads and braided stainless lines before you do big brakes. The stock CRX Si brakes are plenty fine for a lot of racecars. I often regret converting to Integra brakes.
Old Nov 29, 2003 | 04:35 PM
Pfieff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">warped and worn stock rotors/pads with over 100,000 miles gets a little scary sometimes, but the look on the passengers face makes it worth it </TD></TR></TABLE>
Yea, you have to get something else in there. I think we are going to die everytime.
Old Dec 4, 2003 | 08:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">Where do you guys get your brembo blanks from, and what do you pay?</TD></TR></TABLE>
I'd like to know also!
Old Dec 4, 2003 | 08:42 PM
raene's Avatar
I got mine from the local parts store. They're just stock replacement rotors, nothing special about them.
Old Dec 4, 2003 | 08:47 PM
BlueSi2k's Avatar
Default Re: (raene)
I got mine from enthusiasts auto they had a group buy in the sponsors section. $28 each for the fronts and $22 each for the rear.
Old Dec 4, 2003 | 09:25 PM
pornstarSR's Avatar
Default Re: (BlueSi2k)
for awhile the realtime integras ran stock all the way around...not sure about now....but they said stock worked better than they could have imagined...
most of the crossdrilled they used cracked after one race...
Old Dec 4, 2003 | 10:32 PM
illi Adik's Avatar
Default Re: (pornstarSR)
Brembo slotted and dimple drilled, Axxis Pads, Earls stainless lines, and Super Blue Brakefluid. This set up has worked excellent for about 2 years now.
Old Dec 4, 2003 | 10:50 PM
Default Re: (Jackson4Door)
Do Brembo blanks make much of a difference? I really want strong brakes that I can trust, regardless of cost.
Old Dec 5, 2003 | 07:57 AM
raene's Avatar
The Brembos are simply high-quality replacement rotors. Just a solid piece of metal. Can you trust it? Of course! Can you trust cross-drilled rotors? I wouldn't. I've personally cracked a set.
I think we can all agree that pad-to-rotor contact is what stops a car. Cross-drilled rotors have less pad-to-rotor contact, plain and simple. So what'll stop better, a blank or a cross-drilled...?
Old Dec 5, 2003 | 08:06 AM
Bnjmn's Avatar
Correct, Realtime they ran these because they were allowed to use the ITR ABS system as well. They then switched to some jigadollar Brembo setup.
Rules prohibit them from running a big brake upgrade and ABS.
This should give you a good idea about how good the ITR ABS and stock brake system is, not to mention the ITR ABS with a big brake upgrade.
For those that care- the ITR ABS is an independent system and can be installed on any car that you can get the Integra ABS sensors on.
ITR ABS + StopTech kit = Best.
Ben
Old Dec 5, 2003 | 08:35 AM
DIRep972's Avatar
Smarter than you
Default Re: (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Correct, Realtime they ran these because they were allowed to use the ITR ABS system as well. They then switched to some jigadollar Brembo setup.
Ben
so ITR abs is different then Integra ABS?
Old Dec 5, 2003 | 08:38 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Brembo cross drilled/slotted rotors and aem brake pads. Cant do anything to serious when you gotta run a 13" slick.</TD></TR></TABLE>
Yeah, I am in teh same boat for the 13" slicks.
I have Powerslot rotors all around, AEM (Nissin) pads, Stainless lines. It stops on a dime.
