JRSC help please.. alternator upper bracket bolt size
Old Nov 30, 2003 | 07:00 PM
BringIT's Avatar
Default JRSC help please.. alternator upper bracket bolt size
Can anyone tell me the size of the bolt I need for the upper alt bracket? This is the bolt that goes into the head right under the valve cover.
Also, what is used to seal off the coolant line on the block that is no longer used?
Old Nov 30, 2003 | 09:02 PM
CRVRX's Avatar
Default Re: JRSC help please.. alternator upper bracket bolt size (BringIT)
The bolt is a 10mm x 20mm , It will have a 14mm head which is a common size on your Honda.
To Block off the hose you don't need, The best way is to have it welded. The other way is to buy a coolant plug ( not vacume) and use a hose clamp.
PYITR01
Sep 17, 2011 09:35 AM
dcraige
May 28, 2010 09:54 AM
dbailey
13
Jan 20, 2010 12:25 PM
shbrown
Feb 20, 2006 08:15 PM
ihaveamustang
Jul 3, 2005 04:29 PM
