thermostat
Old Dec 1, 2003 | 03:38 AM
scatuli's Avatar
Default thermostat
i am not overheating but i do run pretty hot and yes i understand a turbo will cause this but if i could lower it a little bit it would be great.
i heard not to get a 160 becuase it wont get warm enough to let the car know that it is warmed up i read that it needs the get to about 165 so i was wondering what the lowest i could get would be. and what do b18as comes with stock?
Old Dec 1, 2003 | 04:01 AM
scatuli's Avatar
Default Re: thermostat (scatuli)
anyone?
Old Dec 1, 2003 | 12:28 PM
scatuli's Avatar
bump
Old Dec 1, 2003 | 02:09 PM
Johnyquest's Avatar
My car is boosted and it doesn't run hot. Maybe it's time for a cooling system overhaul. Stick with the stock thermostat temperature.
Old Dec 1, 2003 | 02:26 PM
99B16Si's Avatar
even if u have a 160deg thermostat the car will still operate at about 10deg higher than that. i have a 160deg in my car and it works great.
Old Dec 1, 2003 | 02:29 PM
Rico's Avatar
I had the same problem you might have some air in the cooling system.
Old Dec 1, 2003 | 02:52 PM
allablur's Avatar
Default Re: (Rico)
i picked up a mugen thermo and relay
Old Dec 1, 2003 | 03:16 PM
DIRep972's Avatar
Smarter than you
Turbo will not make u run hot. You have a problem elsewhere.
Old Dec 1, 2003 | 05:28 PM
scatuli's Avatar
Default Re: thermostat (DIRep972)
so you are saying a turbo will not produce more under the hood temp?
becuase by me doing the lower thermostat i am trying to lower it a little
Old Dec 1, 2003 | 05:33 PM
booscivic's Avatar
Where you guy bought the mugen relay from>?
Old Dec 1, 2003 | 06:36 PM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scatuli &raquo;</TD></TR><TR><TD CLASS="quote">so you are saying a turbo will not produce more under the hood temp?
becuase by me doing the lower thermostat i am trying to lower it a little</TD></TR></TABLE>
under hood temps might go up but ur motor still runs at the same temperature.
Old Dec 3, 2003 | 01:37 PM
99B16Si's Avatar
ditch the hood....problem solved
zsiya
Feb 8, 2013 05:36 PM
chafetzk
Nov 27, 2010 11:05 AM
gbg2w1
Aug 30, 2008 05:43 PM
the.hamburglar
Jun 15, 2008 11:27 AM
Jay_Sensing
Apr 23, 2006 10:50 AM
