In a bind. need some help. piston to wall clearance.
Old Nov 29, 2003 | 08:46 AM
5thgencivic's Avatar
Default In a bind. need some help. piston to wall clearance.
I bought some used SRP pistons on here for a d16z6. they are standard bore. I also picked up a used motor at the junk yard. The sleeves look to be in great shape and the factory hone marks are still visible. I just got a call from the machine shop that the piston to wall clearance would already be .005 to .006. What should I do? I was hoping to get it around .003. Thanks for any help.
Nate
Old Nov 29, 2003 | 09:45 AM
Flamenco-T's Avatar
Default Re: In a bind. need some help. piston to wall clearance. (5thgencivic)
I would call and check with JE/SRP about the wall to skirt clearance. .005 is way too loose, unless they expand like crazy...Normal forged pistons usually requires .002-.004 of clearance, and all depends on the silicon content on the piston.
stan
Old Nov 29, 2003 | 09:53 AM
Default Re: In a bind. need some help. piston to wall clearance. (Flamenco-T)
It's supposed to be in the .003 range. I looked on the JE site. I'm screwed now because the block is already posted. My fault though, since I should have checked the clearance before hand. My only option would be get another block that's less worn, or buy oversized pistons right? thanks.
Old Nov 29, 2003 | 03:26 PM
Bnjmn's Avatar
You can send you pistons to Endyn and they have some special ceramic coating that will build up clearance. Go to http://www.theoldone.com and send them an email.
Ben
krazyturbo1
Jan 8, 2008 07:22 PM
hatchinprogress
Nov 14, 2005 08:36 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
crx1856
Nov 3, 2003 12:00 AM
