What ecu work on my 99 Si when running hondata.
Old Dec 1, 2003 | 03:11 PM
allstokhonda's Avatar
Default What ecu work on my 99 Si when running hondata.
Like stated above I'm ordering hondata and have access to a p72 ecu. I know I will need the obd2-obd1 conversion harness. will the p72 work since I have a b18c1 bottom-end and my b16a2 head.
Old Dec 1, 2003 | 03:22 PM
.... anyone. I know there's some smart people that could help me out
Old Dec 1, 2003 | 03:23 PM
11psiTurboSI's Avatar
Default Re: What ecu work on my 99 Si when running hondata. (allstokhonda)
Yes, you can use a P72!
Clutch101's Avatar
Yes...the P72 will work fine. It might throw a code for the IAB. not real sure.
I'm running a P28 but I'm using the old Stage 3b.
Old Dec 1, 2003 | 03:25 PM
Default Re: What ecu work on my 99 Si when running hondata. (JDMwannaB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMwannaB &raquo;</TD></TR><TR><TD CLASS="quote">Yes...the P72 will work fine. It might throw a code for the IAB. not real sure.
I'm running a P28 but I'm using the old Stage 3b.</TD></TR></TABLE>
what is IAB, and is there any good or bad things about running the p72. vs the p28
Old Dec 1, 2003 | 03:30 PM
Clutch101's Avatar
You can usually pick a P28 up cheaper if you don't have a ECU.
The IAB or secondary intake runner is a set of butterflies in the intake manifold of B18C and H22A engines. The P72 ECU controls the IAB, but other ECUs do not.
Old Dec 1, 2003 | 03:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMwannaB &raquo;</TD></TR><TR><TD CLASS="quote">You can usually pick a P28 up cheaper if you don't have a ECU.
The IAB or secondary intake runner is a set of butterflies in the intake manifold of B18C and H22A engines. The P72 ECU controls the IAB, but other ECUs do not.</TD></TR></TABLE>
Oh ok I remember reading about the butterflies. I"m running a jg victoryx intake manifold and it's gonna be on my b16 head on the b18c1 block. I can get the p72 ecu from my friend. but thanks
Old Dec 1, 2003 | 03:35 PM
Clutch101's Avatar
Cool! Good luck with the build.
Old Dec 1, 2003 | 03:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMwannaB &raquo;</TD></TR><TR><TD CLASS="quote">Cool! Good luck with the build.</TD></TR></TABLE> ok thanks for the help
jmacsss
Apr 17, 2011 07:14 PM
that_sick_eg
Engine Management and Tuning
10
Feb 8, 2011 08:49 AM
EF_LSVtec
Apr 18, 2006 04:43 AM
PreludeSiTdriver
Oct 26, 2004 03:35 PM
Mike95lude
Jul 12, 2003 09:35 PM
