lsvtec civic on dyno
Old Nov 30, 2003 | 10:49 PM
1.8turbolsvtec's Avatar
Default lsvtec civic on dyno
i just went over 5000 miles on my swap wanted to take it to the dyno .it is a built motor sleved ,pistons ,rods ,my ? is 245 at 6 psi a good run. o and i have type r cams to with hondata getting ready to see what 20 psi will make .just seening what you all think if that was were 6psi is at with what i got .thanks good or no good
Old Nov 30, 2003 | 11:20 PM
Mr. Softee's Avatar
Default Re: lsvtec civic on dyno (1.8turbolsvtec)
looks good so far.
Old Nov 30, 2003 | 11:45 PM
TurboDANDEE's Avatar
Default Re: lsvtec civic on dyno (94goldjungsr)
sounds good man
Old Dec 1, 2003 | 03:57 AM
rocket256's Avatar
lt looks good bro.
Old Dec 1, 2003 | 07:45 AM
SpoolnG2's Avatar
Default Re: lsvtec civic on dyno (rocket256)
what c/r are you using though?
Old Dec 1, 2003 | 04:05 PM
Default Re: lsvtec civic on dyno (SpoolnG2)
the car is a 95 civic ex looks stock have si civic rims red
Old Dec 1, 2003 | 04:08 PM
norcalcrx's Avatar
He was asking what your engines compression ratio was (c/r) Ie: 9.5 to 1
Old Dec 13, 2003 | 05:07 PM
Default Re: lsvtec civic on dyno (norcalcrx)
it has b16 9 to1 flat tops in a ls vtec i thing it is over 10,1
Old Dec 13, 2003 | 05:11 PM
DOHCarp's Avatar
I dynoed 268 whp @ 7 psi running 9.5:1 stock bottom end. Your numbers don't sound that off, but what is the exact CR?
Old Dec 13, 2003 | 05:19 PM
PrecisionH23a's Avatar
Any reasons you are still running the itr cams? I was always under the impression the GSR ones are the best OEM ones for FI.
Old Dec 13, 2003 | 05:37 PM
baphomet's Avatar
Default Re: lsvtec civic on dyno (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Any reasons you are still running the itr cams? I was always under the impression the GSR ones are the best OEM ones for FI.</TD></TR></TABLE>
Who says ITR cams suck for boost?Integra Type R cams and Boost=616whp/375ft-lb torque!
Old Dec 13, 2003 | 05:39 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec &raquo;</TD></TR><TR><TD CLASS="quote">i just went over 5000 miles on my swap wanted to take it to the dyno .it is a built motor sleved ,pistons ,rods ,my ? is 245 at 6 psi a good run. o and i have type r cams to with hondata getting ready to see what 20 psi will make .just seening what you all think if that was were 6psi is at with what i got .thanks good or no good </TD></TR></TABLE>
What RPM are you taking it to?
Old Dec 13, 2003 | 05:40 PM
Default Re: lsvtec civic on dyno (slashDEVslashNULL)
Holy guacamole! I never said they suck, I just thought the GSR ones are more benificial since the cam profile overlap is not as severe as the ITR's are.
Old Dec 13, 2003 | 05:46 PM
danny0cean's Avatar
looks good to me first post woo hoo...
Old Dec 14, 2003 | 12:32 PM
streetlvlhatch's Avatar
Default Re: lsvtec civic on dyno (danny0cean)
numbers look sick!!!! It's making me pretty happy to see these numbers seeing as how i am doin ls/vtec turbo!!
Old Dec 14, 2003 | 02:06 PM
baxter04's Avatar
looking good!
Old Dec 14, 2003 | 02:26 PM
Default Re: lsvtec civic on dyno (baxter04)
I JUST HAD THE TYPR R CAM SO I PUT THAM IN AND MY RPM WAS AT 7800 DID NOT TO GO MUCH MORE . ANY ONE KNOW WHAT THEY THINK IT WILL MAKE AT 20 PSI O YA THE TURBO IS 60-1 DO YOU GUYS THINK I NEED A BIGGER ONE
mangina
Sep 15, 2008 07:57 PM
chadmasterc
12
Oct 21, 2006 10:57 AM
RZFD
Apr 26, 2005 11:56 AM
RedTegLS
Feb 3, 2004 07:06 PM
