newb question
Old Dec 1, 2003 | 01:49 PM
mattssi's Avatar
Default newb question
I am still new to turbo's, but i like asking questions! On the compressor, there is a threaded bolt hole? What is this for? I can't figure it out, the kit didn't come with any fittings to plug this, are you supposed to leave it open? if i do, wouldn't it cause a boost leak! Or is it some safety precaution?
Old Dec 1, 2003 | 02:13 PM
rjardy's Avatar
Default Re: newb question (mattssi)
Its just a source to bet your boost/vaccum signal from. I have mine running to my wastegate for activation.
Rob
Old Dec 1, 2003 | 03:13 PM
mattssi's Avatar
Default Re: newb question (rjardy)
Thats a pretty good idea! That is probablt what it is meant for? Thanks for the reply, i just couldn't figure it out?
Old Dec 1, 2003 | 07:17 PM
rjardy's Avatar
no problem, allot of people use that port for that. Good luck with your setup.
Rob
Old Dec 1, 2003 | 07:37 PM
HXMan's Avatar
Are you better off using the port off the turbo or a source off the manifold?
I would think the manifold, the port of the turbo may show 10psi, but after the IC and other restrictions won't you read less?
Old Dec 1, 2003 | 07:46 PM
Cramerox's Avatar
Default Re: newb question (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Are you better off using the port off the turbo or a source off the manifold?
I would think the manifold, the port of the turbo may show 10psi, but after the IC and other restrictions won't you read less?</TD></TR></TABLE>
exactly....if you tap on the charger pipe or intake mani you will get a reading after the IC...it will match the readin on your boost gauge
Old Dec 2, 2003 | 09:13 AM
mattssi's Avatar
Default Re: newb question (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">
exactly....if you tap on the charger pipe or intake mani you will get a reading after the IC...it will match the readin on your boost gauge</TD></TR></TABLE>
That makes sense! So I am going to just tread a bolt in there to plug it up!
Old Dec 2, 2003 | 09:20 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">
That makes sense! So I am going to just tread a bolt in there to plug it up! </TD></TR></TABLE>
Old Dec 2, 2003 | 09:38 AM
HXMan's Avatar
Thats what I thought.
Maximum Boost does come into handy sometimes.
Ntense90crxsi
Aug 18, 2009 08:07 PM
007EG
Dec 14, 2007 04:27 PM
007EG
Nov 15, 2007 03:55 AM
CBURKE
May 23, 2006 06:02 AM
c-notecoupe
Dec 23, 2001 12:28 PM
