Buliding a transmission for Boost?
Old Nov 30, 2003 | 01:07 PM
TurboB18C1's Avatar
Default Buliding a transmission for Boost?
i dont know much about trasmissions.....so
So far I know strong axles are needed for a boosted Honda but my question is does it matter if you choose a gear ratio set before you know the full potential of your motor? (HP)
Looking into Kaaz’s Gear set {MCH1850} w/ Final Drive {FGH1835} and
Acura/Honda level 3 Hybrid axle’s
LSD ??
Also if anybody can post the Gear Ratios of a stock GSR Tyranny (98’) would be helpful
Setup- street/strip
stock gsr tranny
JDM 5 lug (36 mm axle nut)
act extreme plate clutch setup
Old Nov 30, 2003 | 02:40 PM
DaveF's Avatar
Default Re: Buliding a transmission for Boost? (TurboB18C1)
only thing i would do is get a quaife LSD, and stronger axles from whichever company you desire and than call it a day.
Old Dec 1, 2003 | 11:52 AM
TurboB18C1's Avatar
Default Re: Buliding a transmission for Boost? (2.2Lcivic)
what kind of axles do you recommend?
450-500hp
Remeamber i have a JDM 5 Lug (36mm axle bolt) i dont know if it matters or not?
Old Dec 1, 2003 | 12:32 PM
nojoke's Avatar
Driveshaftshop should make it custom for you if there is a problem, call them up and ask.
Old Dec 1, 2003 | 02:44 PM
sol2nr's Avatar
Default Re: (nojoke)
i love my driveshaft shops. good customer service too. smoother acceleration when i changed them over from stock.
Jonknee
Jul 21, 2025 08:51 AM
bdavis
Mar 24, 2009 03:31 PM
DSRxCandyh2bEG
Sep 24, 2008 04:07 PM
ls2typer15
Aug 19, 2008 07:07 PM
sweettooth
Apr 18, 2002 06:13 AM
