what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!!
I'm am in the ordering proccess right now of gettin all the parts for my engine build. I'm build a 2.0L darton sleeved gsr with my b16 head. it gonna have 9.0:1 cr and I looking to run around 15-18 psi around town and 20-23 psi at the track on race gas. are precision injectors anygood. I don't know much about them. just that I can get 880cc for around 75$ (each) and 1000cc or like 85-90. anybody with any knowledge of this that would like to post. WOuld be greatly appriciated.
Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (allstokhonda)
i had one set fail but ever since that not single failure .. they use Rochestor Core in there mid range injectors from 680cc-1000cc and the 1600cc is a bosch unit
the 880cc should be good for your setup
Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">i had one set fail but ever since that not single failure .. they use Rochestor Core in there mid range injectors from 680cc-1000cc and the 1600cc is a bosch unit
the 880cc should be good for your setup</TD></TR></TABLE>
thanks for the reply. I was told that I need a resistor box. if so do you know of anywhere I can locate or purchase one. also I talk to kyle at wiredspeed and he recommended them but I just figured I could look around and talk to some more people.
we use the 880's and have no problems with them at all.
you will need a resistor box.
i was under the impressoin that they were delphi injectors?
Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (JDogg)
GM delphi uses rochestor product if you take a look at your injector you will see RP cast on the side of the injector
[QUOTE=JDogg]we use the 880's and have no problems with them at all.
QUOTE]
what kinda power are you making and/or et's/ in what car
QUOTE]
Re: (allstokhonda)
get them they are good priced works great compared to the outragerous price of RC also you can check out another brand called Simen Deka i think camp1320 sells them on here
Re: (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">get them they are good priced works great compared to the outragerous price of RC also you can check out another brand called Simen Deka i think camp1320 sells them on here </TD></TR></TABLE> yeaht that's what I'll probably do. yeah the RC are freakin 180 each. that's a little high compared to precisions only being 75-90$ each.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allstokhonda »</TD></TR><TR><TD CLASS="quote">[QUOTE=JDogg]we use the 880's and have no problems with them at all.
QUOTE]
what kinda power are you making and/or et's/ in what car</TD></TR></TABLE>
last time we were on the dyno we made 510hp and 375 tq. we are close to maxing the injectors out, the base pressure is around 55 psi
QUOTE]
thanks for the reply. I was told that I need a resistor box. if so do you know of anywhere I can locate or purchase one. also I talk to kyle at wiredspeed and he recommended them but I just figured I could look around and talk to some more people.</TD></TR></TABLE>
just buy some resistors from radio shack for like $2.
Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg »</TD></TR><TR><TD CLASS="quote">
just buy some resistors from radio shack for like $2. </TD></TR></TABLE>
or go get one out of any 90-97 accord or 92-96 prelude or 88-91 civic for bout 20 bux
what kind of ECU are you using to run the injectors? You don't necessarily need a resistor box unless you're running an ECU that's setup for high impendence injectors.
Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (boostaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic »</TD></TR><TR><TD CLASS="quote">what kind of ECU are you using to run the injectors? You don't necessarily need a resistor box unless you're running an ECU that's setup for high impendence injectors. </TD></TR></TABLE>
what ecu could he run with low impedence injectors without a resistor box?
what ecu could he run with low impedence injectors without a resistor box?</TD></TR></TABLE>
Autronic, Motec, Speedpro/FAST, DFI, and haltech all have built in drivers for low impendence injectors.
Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (TurboDANDEE)
I just picked up a set of Precision 880cc injectors from Arturbo. I'm putting my trust in them.
Re: (slowsi00)
BACK FROM THE DEAD, im about to pick up a set of precission 450cc injectors from a friend for pretty cheap. putting them in my SOHC... its a d16z6 in an EG hatch... do i need a resistor box aswell? and what is it used for? keeps them from being over powered or something?
also did anyone ever use these on a sohc? did you have any problems? where they enough for your setup? im shooting for 250whp stock motor..
