What is the difference between a b18a and a b18b ??
Old Nov 30, 2003 | 05:30 PM
95lsteg's Avatar
Default What is the difference between a b18a and a b18b ??
My b18b is going turbo. I'm being offered a b18a for cheap. Thinking of buying it for parts or replacement if I blow mine. What you can say??
Thanks
Old Nov 30, 2003 | 07:06 PM
scatuli's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (95lsteg)
as far as i know they are pretty identical the deck hieght is a little different and the b18b has a little better cam giving it 10 ish more hp
Old Nov 30, 2003 | 07:30 PM
eG_6ix's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (scatuli)
like scatuli said, the main difference is the camshafts...so i think if you fould a good deal on a b18a, i would go for it
Old Dec 1, 2003 | 04:15 PM
95lsteg's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (eG_6ix)
Thats it? Just the camshafts? The guy that offered it to me totaled his car. He asked for just $200.
Old Dec 1, 2003 | 04:38 PM
dwilson's Avatar
If you dont want it i do
Old Dec 1, 2003 | 05:27 PM
The_Head's Avatar
The B18B also has a better designed head that flows just a bit better than the B18A's
Old Dec 1, 2003 | 06:04 PM
GDM Z28's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (xThexHeadx)
if you buy the b18a ill sell you some b18b cams crom a 97 or 96 ls head. i heard these are beefy for stock cams. my friend that i got the head off of use to beat other ls eg's stock vs stock with driver capabilities being the same as well.
Old Dec 1, 2003 | 06:59 PM
Joseph Davis's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (civicflnum1)
THe bottom end is identical, the difference is in port size, IM design, cam profile, and ECU tune.
Remember, 90-91 B18A made 130 hp, 92-93 B18A made 140 hp, 94+ B18B made 142 hp. Big whoopty ****.
Old Dec 1, 2003 | 07:12 PM
DaveF's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">. Big whoopty ****.
AMEN
Old Dec 2, 2003 | 03:43 AM
GDM Z28's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (2.2Lcivic)
well in that case i have a b18b intake manifold for sale as well as the cams
Old Dec 2, 2003 | 07:59 AM
haggar's Avatar
when I put a 1994 B18B head next to a 1990 B18A head, and measured ports with my calipers, they were the same opening size. Passages looked identical to the naked eye, too. chambers also looked the same.
Intake runners I believe are shorter on the B18B..moved the powerband up a few hundred rpm.
Old Dec 2, 2003 | 08:22 AM
Mr. Softee's Avatar
Default Re: What is the difference between a b18a and a b18b ?? (haggar)
IM, cams
Old Dec 2, 2003 | 09:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haggar &raquo;</TD></TR><TR><TD CLASS="quote">when I put a 1994 B18B head next to a 1990 B18A head, and measured ports with my calipers, they were the same opening size. Passages looked identical to the naked eye, too. chambers also looked the same. </TD></TR></TABLE>
Hrm, I know there is a visible difference between port sizes if you lay two heads next to each other. Half the B18A **** I have laying around is automagic, so that may be the difference between your findings and mine.
Old Dec 2, 2003 | 10:17 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eG_6ix &raquo;</TD></TR><TR><TD CLASS="quote">like scatuli said, the main difference is the camshafts...so i think if you fould a good deal on a b18a, i would go for it</TD></TR></TABLE>
Is there no difference in compression...? The B18A still has a 9.2:1 compression...? I don't know either way, but it seems that the B18B might have a little higher compression... Neone know for sure...?
Old Dec 2, 2003 | 10:49 AM
Muckman's Avatar
Moderator in Chief
Gen2 vs Gen3
Its a B series and alot of the misc parts should swap over.
Old Dec 2, 2003 | 10:56 AM
VTC_CiViC's Avatar
Hrm, I know there is a visible difference between port sizes if you lay two heads next to each other. Half the B18A **** I have laying around is automagic, so that may be the difference between your findings and mine. </TD></TR></TABLE>
Maybe you were comparing the 90-91 A's to the B's whereas the 92-93 A's and B's use the same head design.
Old Dec 2, 2003 | 02:00 PM
Default Re: What is the difference between a b18a and a b18b ?? (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you were comparing the 90-91 A's to the B's whereas the 92-93 A's and B's use the same head design.</TD></TR></TABLE>
That could be it. I was given a bunch of the heads to use as welding jigs, but do remember I tore one of the small port B18A's off of a 90 LS. The rest I really don't know the what/when/where/why of.
Old Dec 2, 2003 | 04:28 PM
95lsteg's Avatar
Thank you all for the info. What I'm really interest (block, crank) seems to be the same as my b18b, just in case I blow it.
Old Dec 3, 2003 | 04:10 PM
Mr. Softee's Avatar
joseph, from blundar (from a pgmfi post )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">correct. B20, B18B and B18A all use the same head casting.</TD></TR></TABLE>
b16
Jul 3, 2003 06:33 AM
crxjake
Jun 16, 2003 02:14 AM
CRXSleeper
17
Sep 17, 2002 06:42 PM
lildrgn2.0
Jun 24, 2002 02:23 PM
H22CIVIC
Nov 21, 2001 10:20 AM
