Helpme turbocharge my b17for less than 500 dollars
OK
i was thinking this setup=
-t25
-custum manifold?
-eclipse sidemount with custum piping
-dsm bov or cheap bosch etc
-injectors?
-all the lines etc im not sure about
help me?
i have a b&m fpr and i hav an air/fuel gauge but its an autometer which is more of a lightshow i hear(its uninstalled)
-t25
-custum manifold?
-injectors?
help me?
ill try my best....
turbo you can do a T3 .48/.60, t25, or a 14b. all easy to find and should be cheap
Manifold will probably be your most challenging task. if you know a welder you can make a tube mani for around 50-70 which would be the flanges and the piping...otherwise i dont know exactly what you could do
There are plenty of small FMICs at the junkyard. SMIC, probe ic...the list is pretty much endless. you should be able to grab any of those for $20-50.
Piping, i suggest going to a meinkie or some place like that and asking if you can check out some of the piping they are going to throw out...or sometimes junkyards have a nice collection of piping
DSM 1g BOV would be your best bet
Injectors...im almost tempted you can stay stock depending on your boost level....i would suggest 450cc out of a DSM w/ a resistor box i guess?
Fuel management....probably an FMU or maybe you can swing chipping your ECU...
Its possible to run a $500 or less turbo setup....i think to make it work well you have to have a good amount of knowledge...for example i wouldnt be able to do it..i just wanted to give you some suggestions
Re: (bigwig)
You only need to spend $35 right now. Buy Maximum Boost by Corky Bell.
You've got too many conflicting questions and not a very firm grasp of what is going on right now. Put off plans to buy anything else a whole month and read the above book. Smurf over http://www.homemadeturbo.com for cheap successful setups, and peek into the (recently locked and now archived) Uberdata thread, which is just a search away.
Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">You only need to spend $35 right now. Buy Maximum Boost by Corky Bell.
This is a very good suggestion. I got this book for christmas last year from my G/F, i have read it 2 times and honestly I still read it. ITs full of great theory on turbocharging. Any custom turbo kit should start here, with this book.
Rob
Rob
ringgold
Welding / Fabrication
24
11-29-2004 12:13 PM
Scotty
06-16-2001 11:27 AM
