how much boots?
Old Nov 29, 2003 | 11:56 PM
KDM_POWER's Avatar
Default how much boots?
i have 97 civic stock HX motor and running t3 turbo. but
i like to know how much of boost(psi) i sould run for everyday drive?
i was planing to run 8psi was but please tell me how much i shold run?
Old Nov 30, 2003 | 12:28 AM
PHiZ's Avatar
Default Re: how much boots? (KDM_POWER)
Hrm, I'd like to hear some tuning theory about this motor and vtec-e.
-PHiZ
Old Nov 30, 2003 | 12:47 AM
liam821's Avatar
25 Year Member
Default Re: how much boots? (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Hrm, I'd like to hear some tuning theory about this motor and vtec-e.
-PHiZ</TD></TR></TABLE>
agree. Although the block is the same as the y7/y8 and is strong enough for 8-10psi with good tuning.
liam
Old Nov 30, 2003 | 07:20 AM
LSiTurbo's Avatar
Default Re: how much boots? (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
I got some timba-lands y0! 20 dollas! j/k
Old Nov 30, 2003 | 08:56 AM
PHiZ's Avatar
Default Re: how much boots? (LSiTurbo)
http://www.leecao.com/honda/vtec/sohcvtece.html
Here is the VTEC-E theory.
Before vtec-e engages you are operating off of one intake valve, which promotes flow velocity, and combustion chamber swirling, resulting in more efficient burn.
When vtec-e is engaged it opens up the other intake valve.
So for turbo operation, you would want to engage vtec at a very very low RPM. You could even conceivably wire the vtec solenoid always on, or do some headwork and "pin" the vtec lobes always on.
I don't know the longlevity of the solenoid under constant operation like that.
And you can't simply swap cams, because from what I understand the HX has roller rockers to eliminate some valvetrain frictional loss (is that true?)
Basically, I think you would see gains by switching to a 1.6 non-vtec head
As far as actually TUNING around vtec-e, I'll have to think about it and adress it later.
-PHiZ
Old Nov 30, 2003 | 09:18 AM
HXMan's Avatar
I only run one pairbar of boots!
Old Nov 30, 2003 | 10:29 AM
bottlefedb18c1's Avatar
thank god i have a b18c and not worrying about a valve staying closed hahaha
vipcivic
Honda S2000
39
Aug 4, 2008 04:49 PM
JFG Kevin
May 30, 2006 12:07 PM
Special-K-Coupe
Jan 24, 2005 09:22 PM
fuck honda-tech
Aug 27, 2004 07:56 AM
2FastxEg
Dec 7, 2003 04:05 PM
