Help me build my B18b for boost
Old Dec 1, 2003 | 03:48 PM
1slowEK's Avatar
Default Help me build my B18b for boost
okay... right now i got a complete b18b swap chillin in my garage! i wanna boost it for sure but i dont have hella money to go all out with it. I dont wanna sleeve the motor casue that is going to cost hella money! i wanna just build the bottom end for now and go from there... i got some questions tho...
1. What is a good compression to go with? i was thinking 9:1 or 9.2:1
2. What rods should i get?
3. do i need to do anything to the crank?
4. How much boost could my stock sleeves hold with a mild build bottom end?
5. Whats a good head gasket to go with?
6. Should i get stock length rods? what is stock length?
i wanted to boost like 15lbs for race... what do you guys think? help me out and give me some ideas! anything! but like i said befor i dont want to sleeve the motor casue that cost hella money! i dont plan on going all out with this motor... i want it to last... i just want a fast turbo car... not an all out drag car.... pretty much... give me any of your ideas for the motor, not just for the bottom end, but for the whole thing...
Modified by 1slowEK at 8:28 PM 12/9/2003
Old Dec 1, 2003 | 03:51 PM
b18bturbo's Avatar
Default Re: Help me build my B18b for boost (1slowEK)
if tuned properly you can run around 15 psi on the stock block without any issues.
I would start working with a hondata or some nice ecu setup with some larger injectors.
I would reccommend for the head dual valve springs and retainer but thats about it.The stock valve springs tend to lead the valves to float at higher rpms
Old Dec 3, 2003 | 10:32 PM
1slowEK's Avatar
Default Re: Help me build my B18b for boost (b18bturbo)
thanks.... i dont have an ecu in so i was plannin on gettin a p28 n hondata's uhhh s200... but thanks for the help....
also if you guys got any parts for sale... or know where i can get some stuff for cheap help me out....
I need a stock header, wire harness.... and thats all i can think of... oh yea and some mount to go into my 98 hatch
Im also lookin for a ctr rear lip and any side skirts... let me know what you got and ill tell you if i want it... i need urathane <sp? sides please
Old Dec 3, 2003 | 10:50 PM
Lucky_Smurf's Avatar
If motor mounts are what your looking for I'd recommend Jimfabs. I've got em and they work great.
Old Dec 3, 2003 | 11:18 PM
BlackThorN's Avatar
slowek, I"d worry about getting the motor built and TUNED before you worry about the CTR lip and side skirts
just a thought, but it starts to add up faster then you think
<--jsrc intercooled project adding up
good luck
peace
Old Dec 4, 2003 | 04:00 AM
scatuli's Avatar
Default Re: (BlackThorN)
that will be HELLA tight when you get it done
Old Dec 6, 2003 | 01:04 AM
1slowEK's Avatar
BUMP! ( why do people "bump?") i just do it cause... ans what does ttt mean? am i trippin?
Old Dec 6, 2003 | 05:03 AM
TJ R's Avatar
You could check it out here
http://hometown.aol.com/bahraini1/index.html
Good luck man
Old Dec 6, 2003 | 08:21 AM
BlackThorN's Avatar
ttt means to the top
people bump to put their thread to the top of the forum so other people can see it
NICK
Old Dec 6, 2003 | 07:18 PM
1slowEK's Avatar
Default Re: Help me build my B18b for boost (BlackThorN)
bump! haha
Old Dec 8, 2003 | 01:01 PM
1slowEK's Avatar
bump
i still need a stock header, wire harness for the motor and uhhh ob2 to obd1 wire conversion... a p28 if anyone got one...
Old Dec 9, 2003 | 12:54 AM
1slowEK's Avatar
super bump!
Old Dec 9, 2003 | 11:26 AM
1slowEK's Avatar
bump
Old Dec 9, 2003 | 11:42 AM
Blackack26's Avatar
go here
https://honda-tech.com/zeroforum?id=39
Old Dec 9, 2003 | 01:27 PM
TurboJesse
Guest
Posts: n/a
Default Re: Help me build my B18b for boost (Blackack26)
why do you need a header?
Old Dec 9, 2003 | 10:37 PM
1slowEK's Avatar
Default Re: Help me build my B18b for boost (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">why do you need a header? </TD></TR></TABLE>
Because i dont have one on my motor... hahah i dont plan to drop the motor with the turbo... imma run the semi-built motor for a little bit to break it in while i save money to piece together my custom turbo kit...
Modified by 1slowEK at 8:30 AM 12/10/2003
Old Dec 10, 2003 | 01:33 PM
BlackThorN's Avatar
I"m selling a supercharger for a B18B you could run 11lbs all the time
no lag just boost!
https://honda-tech.com/zerothread?id=700208
Old Dec 10, 2003 | 01:43 PM
1slowEK's Avatar
i dont want a supercharger... i want turbo
Modified by 1slowEK at 8:38 AM 12/11/2003
Old Dec 10, 2003 | 08:42 PM
BlackThorN's Avatar
I have no idea what the first part of that sentance means...but good luck
Old Dec 10, 2003 | 11:38 PM
PHiZ's Avatar
I sell OBD2-&gt;OBD1 harnesses, and also, if you're not running a vtec motor, all you need is an OBD1 PR4, P75, P74 or P06 to run hondata.
-PHiZ
Old Dec 11, 2003 | 12:43 AM
1slowEK's Avatar
Default Re: (PHiZ)
i heard that hondata s200 is best for tuning with a p28... and that hondata has a vtec kill switch or something so that i can run it.. im i wrong? if i am... what would be the best non-vtec ecu to run s200 with?
plus i was thinkin about gettin a vtec head... so i might need the vtec ecu...
What would be a tite head gasket? and would i get a head gasket made for my block... or for the B16 head? you knwo what i mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">I sell OBD2-&gt;OBD1 harnesses, and also, if you're not running a vtec motor, all you need is an OBD1 PR4, P75, P74 or P06 to run hondata.
-PHiZ</TD></TR></TABLE>
Old Dec 11, 2003 | 08:02 PM
1slowEK's Avatar
Bump
Modified by 1slowEK at 5:40 AM 12/14/2003
Old Dec 13, 2003 | 08:40 PM
1slowEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowEK &raquo;</TD></TR><TR><TD CLASS="quote">Bump
Modified by 1slowEK at 5:40 AM 12/14/2003</TD></TR></TABLE>
Old Dec 15, 2003 | 09:46 AM
1slowEK's Avatar
Bump!
Modified by 1slowEK at 9:19 AM 12/16/2003
Old Dec 16, 2003 | 12:20 AM
1slowEK's Avatar
BUMP!
