Help! My setup is overboosting..
Old Jul 18, 2004 | 05:01 PM
vtec.dc2's Avatar
Default Help! My setup is overboosting..
Nothing seems to be missing or disconected. Basically, my EBC has several boost level settings. no matter where i set it, even off wastegate spring, it overboost.
What could be the cause?
Old Jul 18, 2004 | 06:23 PM
vtec.dc2's Avatar
Default Re: Help! My setup is overboosting.. (vtec.dc2)
Anybody?
Old Jul 18, 2004 | 06:27 PM
B18C1CYA's Avatar
whats your setup?
Old Jul 18, 2004 | 06:33 PM
vtec.dc2's Avatar
Default Re: Help! My setup is overboosting.. (B18C1CYA)
tial 35mm wastegate. hondata w/ stock map sensor. everythning was going fine until lately its been overboosting by a little at every setting, but now its very inconsistant and overboosting by a lot on every settting.
Old Jul 18, 2004 | 06:36 PM
B18C1CYA's Avatar
what mani and where is your wastegate tapped in to?
Old Jul 18, 2004 | 06:39 PM
vtec.dc2's Avatar
inline pro, wastegate is tapped from IM
Old Jul 18, 2004 | 06:43 PM
B18C1CYA's Avatar
hum maybe your boost controler is faulty or you have developed a leak in one of the lines going to the wastegate.
Old Jul 18, 2004 | 06:51 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">hum maybe your boost controler is faulty or you have developed a leak in one of the lines going to the wastegate.</TD></TR></TABLE>
thanks, i'll check over vaccum lines again, probably replace boost controller. nothing seems out of place inside engine bay.. so i'm just looking for ideas.
Old Jul 18, 2004 | 06:52 PM
B18C1CYA's Avatar
this y iam out of ideas
Old Jul 18, 2004 | 07:17 PM
rondigs's Avatar
Have you tried to run the wastegate by itself (i.e. eliminating the electronic boost controler)?
Old Jul 18, 2004 | 07:21 PM
B18C1CYA's Avatar
o i misred your post i thought you had a manual controler, what ebc do you have ?
Old Jul 18, 2004 | 07:26 PM
vtec.dc2's Avatar
blitz
Old Jul 18, 2004 | 07:27 PM
vtec.dc2's Avatar
Default Re: Help! My setup is overboosting.. (rondigs)
i will try to bypass and see if it stays consistant
Old Jul 18, 2004 | 07:29 PM
B18C1CYA's Avatar
i dont know any thing about a blitz what setting do they have on them?
Old Jul 18, 2004 | 07:36 PM
vtec.dc2's Avatar
you mean like features? this one allows for 5 boost settings/levels (including wastegate spring setting), i'll try to bypass it, see how things go from there
Old Jul 20, 2004 | 07:25 PM
vtec.dc2's Avatar
when bypassing boost controller, everything seemed to work normal and didn't overboost.. i'll try to replace the boost controller...
specie
Feb 5, 2004 09:38 AM
highmilehatch
Oct 15, 2003 07:44 AM
turbo se
Jun 13, 2003 11:33 AM
1tyme
Apr 6, 2003 05:47 PM
blu_si
Oct 1, 2002 04:20 PM
