am i in deep shit?
Old Jul 19, 2004 | 10:29 AM
DubyaAye's Avatar
Default am i in deep ****?
i fisnish installing my turbo and took it out for a spin boosting on like 5 lbs. and on my third gear pull my engine shut off and it wont start no more. i pop the hood to check for leaks and stuff and found out my vacuum line to the wastegate is off. i heard that once the vacuum line is off it means unlimited boosting, is this true?
Old Jul 19, 2004 | 10:42 AM
USDM 4G VTEC's Avatar
Default Re: am i in deep ****? (DubyaAye)
U probably overboosted and blew the motor
didnt u see more than 5psi???
check for holes on the block or oil pan
and check the dipstick for oil ...if none, u have a hole on the pan......
get under the car and look around.......
Old Jul 19, 2004 | 11:08 AM
MachAF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye &raquo;</TD></TR><TR><TD CLASS="quote">i fisnish installing my turbo and took it out for a spin boosting on like 5 lbs. and on my third gear pull my engine shut off and it wont start no more. i pop the hood to check for leaks and stuff and found out my vacuum line to the wastegate is off. i heard that once the vacuum line is off it means unlimited boosting, is this true?</TD></TR></TABLE>
Yes you heard correctly. The vacuum line will supply the wastegate with manifold pressure which opens the wastegate to limit boost. So if that line was off, you would boost a lot, depending on what turbo you had and your rpm and engine load.
Old Jul 19, 2004 | 11:30 AM
DubyaAye's Avatar
Default Re: am i in deep ****? (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">U probably overboosted and blew the motor
get under the car and look around.......</TD></TR></TABLE>no leaks under the the car. we just push start it and the car keep on want to die out so i gotta give it some gas to get it running and lots of white smokes. i know white smokes sounds bad.
Old Jul 19, 2004 | 12:01 PM
havok hybrid's Avatar
sounds like you blew the head gasket if your lucky.... maybe the ring lands... what fuel setup did you have.. ...
Old Jul 19, 2004 | 12:06 PM
Zakar's Avatar
headgasket for sure
Old Jul 19, 2004 | 12:33 PM
FredoSP's Avatar
Default Re: (MusclecarGuyhasHonda)
compression test ....
Old Jul 19, 2004 | 11:27 PM
DubyaAye's Avatar
Default Re: (FredoSP)
just found out that on the exhaust side of the turbo is leaking oil, can somebody tell me what does it mean now.
Old Jul 19, 2004 | 11:38 PM
Patron's Avatar
Very true, your wastegate can't read how much boost you are running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye &raquo;</TD></TR><TR><TD CLASS="quote">just found out that on the exhaust side of the turbo is leaking oil, can somebody tell me what does it mean now.</TD></TR></TABLE>
Too much oil pressure? Over spun turbo, bad seals.
As for your motor, it's more than likely has a blown head gasket as everyone pointed out. You'll definitely want to do a compression test, if the numbers are off, you better pull the head to inspect the damage. You probably have broken ring lands too.
Old Jul 20, 2004 | 03:43 AM
Siriuswerks's Avatar
was this a used or new turbo. If it was used you probably can figured out why it went bad if it was new you might wanna take some pics and post them up
Old Jul 20, 2004 | 10:52 AM
DubyaAye's Avatar
Default Re: (SiRiUsWeRkS)
its a brand new precision turbo. i ll post pics once i take my head apart tonight.
Old Jul 20, 2004 | 11:25 AM
Tinker219's Avatar
Default Re: (DubyaAye)
It was either the head gasket, or the sleeves. The oil coming out of the turbo is probably due to the increased blow-by going through your engine from roasting the pistons/rings/sleeves, and taking the easiest way out....through the oil return line, through the turbo.
This is the worst case scenario, but if your car just "shut off", its probably as bad as it gets...
Old Jul 22, 2004 | 11:12 AM
DubyaAye's Avatar
i pulled out the head last night and everything looks fine so im going have to check with the rigs later tonight when i get off work.
Old Jul 23, 2004 | 11:18 PM
DubyaAye's Avatar
damn cracked all 4 of my pistons.
piston 1
piston 2
piston 3
piston 4
Old Jul 23, 2004 | 11:20 PM
Arturbo's Avatar
Better than steak
25 Year Member
I am sorry to hear that. Welcome to turbo.
Old Jul 23, 2004 | 11:29 PM
null.'s Avatar
Default Re: am i in deep ****? (Arturbo)
holy damn all 4??!
Old Jul 23, 2004 | 11:30 PM
DubyaAye's Avatar
Default Re: am i in deep ****? (egb18turbo)
yup all 4. i guess its time for a build.
Old Jul 23, 2004 | 11:39 PM
Danger's Avatar
dude that ****** sucks !!!
Old Jul 23, 2004 | 11:47 PM
Drew Peacock's Avatar
Default Re: am i in deep ****? (JonnyDanger)
Damn so your engine lasted what 1 hour boosted.. Goodluck
Old Jul 23, 2004 | 11:49 PM
Charles B.'s Avatar
sorry to hear.
so you took it out for a spin right after you installed it? not sure if it factors in, but did you at least allow some time for the seals to break in? i mean brand new turbo...leaking oil from the exh. side...
Old Jul 24, 2004 | 06:09 AM
Griffin@Camtech's Avatar
Holy **** mad props for getting all 4 at once!! It sucks but hey build it back better then it was and boost it again
Old Jul 24, 2004 | 07:43 AM
Suprdave's Avatar
Thats what you get for ripping on the car without triple checking everything.
Should have driven it straight to a tuner without beating it.
I hope you have someone build the motor who knows what they are doing.
Old Jul 24, 2004 | 07:54 AM
m R g S r's Avatar
Default Re: am i in deep ****? (Suprdave)
Wow, that's even shorter than I had my turbo before my engine blew. (2.5months)
Old Jul 24, 2004 | 08:57 AM
integra-modder's Avatar
Default Re: am i in deep ****? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Wow, that's even shorter than I had my turbo before my engine blew. (2.5months)</TD></TR></TABLE>
2.5 months is quite a while.....ive seen a lot of stupid people push more than they car or take their own hack at tunning and blow their engines within weeks.
Old Jul 24, 2004 | 10:02 AM
Sohc Driver's Avatar
Default Re: am i in deep ****? (integra-modder)
If you ran either Uberdata v1.65 or Hondata..The boost cut would have saved your motor from grenading.
Khoi
