Just a pic for the turbo guys to cherish
Old Jul 18, 2004 | 10:54 AM
non's Avatar
non
Default Just a pic for the turbo guys to cherish
The 1.5L turbo F1 engine from Honda circa 1985 1300+ hp
Old Jul 18, 2004 | 11:00 AM
DENCIO's Avatar
Default Re: Just a pic for the turbo guys to cherish (eg2R)
nice...I want one...
Old Jul 18, 2004 | 11:08 AM
InJ3cted's Avatar
Full Specs? Link?
Old Jul 18, 2004 | 11:14 AM
non's Avatar
non
Default Re: Just a pic for the turbo guys to cherish (InJ3cted)
sorry to this day the entire spec sheet has remained elusive
try google
Old Jul 18, 2004 | 11:40 AM
Frozen E's Avatar
H-T White Ops
That looks sooo bad ***.
Old Jul 18, 2004 | 11:48 AM
egturbo's Avatar
gezzz look at how thick those rods are haha nice setup
Old Jul 18, 2004 | 12:06 PM
G
sh!t happens.
Default Re: Just a pic for the turbo guys to cherish (egturbo)
DAMN speechless
Old Jul 18, 2004 | 12:12 PM
shadow103rd's Avatar
Hey would that fit in a Civic.
Jon
Old Jul 18, 2004 | 12:29 PM
HXMan's Avatar
Damn...Look at the combustion chamber on the head...and how small the stroke looks.
Plus...are the cams held in with a piece that bolts to the head?
Old Jul 18, 2004 | 12:35 PM
92HB_HB's Avatar
Default Re: Just a pic for the turbo guys to cherish (HXMan)
i'LL TAKE two...
Old Jul 18, 2004 | 12:46 PM
AspectIndustries's Avatar
Default Re: Just a pic for the turbo guys to cherish (92HB_HB)
Holy *****.....ANy one got pics of a "honda Circa" call me a noob, but ive never heard of it..-=P Looks insane. How about the new JDM scene. I SWAP THAT VALVE COVER FIRST!@!@@! DIBS!@!@)_ Pimp i tell you..!
Old Jul 18, 2004 | 01:07 PM
non's Avatar
non
Default Re: Just a pic for the turbo guys to cherish (synik)
circa means from
IE the treasure map was circa 1710
there in no honda circa
Old Jul 18, 2004 | 01:19 PM
patdemps's Avatar
I want one.
Old Jul 18, 2004 | 04:41 PM
crawdad689's Avatar
Default Re: Just a pic for the turbo guys to cherish (patdemps)
1300hp off 1.5 L's
= 866hp per litre
jesus, that's gotta be the most hp/displacement Ev4R
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">Holy *****.....ANy one got pics of a "honda Circa" call me a noob, but ive never heard of it..</TD></TR></TABLE>
hawt jawnz, y0...... i gotz to get me one of 'dem Honda Circas, y0
it originally went in a formula 1 race car
that pic makes me HARD
someone get specs for this car plllllease
Modified by crawdad689 at 12:18 AM 7/19/2004
Old Jul 18, 2004 | 04:56 PM
RIPracing's Avatar
Default Re: Just a pic for the turbo guys to cherish (crawdad689)
WOW!!! thats all i got to say
Old Jul 18, 2004 | 05:37 PM
non's Avatar
non
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawdad689 &raquo;</TD></TR><TR><TD CLASS="quote">1300hp off 1.5 L's
= 866hp per litre
Modified by crawdad689 at 9:00 PM 7/18/2004</TD></TR></TABLE>
actually they were battling against BMW who were reportedly make 1470 hp from a 1.5 as well
Top Fuel motors are making 1000 hp per liter presumably since they have no dyno that can measure that much
Old Jul 18, 2004 | 08:29 PM
Sunrise City Rider's Avatar
See, this is how you spool 2 huge turbines...Short Stroke, Lots of RPM...A built b16b will be perfect with a T66 as a daily driver...Even better if you add a deckplate and lengthen the rods, make a custom piston with a Huge Top Ring Land and Rev to 12k around town if you like...
Old Jul 18, 2004 | 09:11 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Just a pic for the turbo guys to cherish (Sunrise City Rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sunrise City Rider &raquo;</TD></TR><TR><TD CLASS="quote">See, this is how you spool 2 huge turbines...Short Stroke, Lots of RPM...A built b16b will be perfect with a T66 as a daily driver...Even better if you add a deckplate and lengthen the rods, make a custom piston with a Huge Top Ring Land and Rev to 12k around town if you like... </TD></TR></TABLE>
so why dont u go build one Zee...hehe
any body have close up pics of the chambers and ports..?
Old Jul 18, 2004 | 09:25 PM
HYREV2NR's Avatar
That motor I beleive was banned from race use cause it was said to be humanly incapable of controlling for it's insane HP even by a well experienced driver. It was also said they were known to have made as much as 1500 HP. About 400 HP per litre.
Old Jul 18, 2004 | 09:41 PM
twkdCD595's Avatar
Default Re: (HYREV2NR)
my math may be rusty but a 1.5l making 1500hp would be 1000hp per litre.
Old Jul 18, 2004 | 09:53 PM
chris05's Avatar
impressive!
Old Jul 18, 2004 | 10:35 PM
TURBODC4TEG's Avatar
Default Re: (tegtuner24)
Old Jul 18, 2004 | 10:40 PM
racinskittle's Avatar
Default Re: (JDMDC4TURBO)
Does it have VTEC?! That's one badass motor
Old Jul 18, 2004 | 11:39 PM
pngfolife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Damn...Look at the combustion chamber on the head...and how small the stroke looks.
Plus...are the cams held in with a piece that bolts to the head? </TD></TR></TABLE>
The valve train is gear driven. At 15,000 RPM, it's kinda hard for a timing belt to stay together. High RPM operation is also why the stroke is so short.
I have some estimated specs out of a 1988 Honda Formula 1 1.5L V-6. This was after all the restrictions took place.
Bore: 3.11"
Stroke: 2"
Rod Length: 3.6"
Combustion chamber: Dual plug pent-roof
Compression: 9.4:1
Intake valves: 1.25"
Exhaust valves: 1.15"
Cam duration: I/E 240 deg. @ .050" lift
Cam lift: 0.400"
Air-to-Water intercooler
Max boost: 33.6 PSI (2.5 bar)
Rated: 685 HP @ 12500 RPM and 313 lb-ft TQ
This all came out of my engine modeling software library.
Old Jul 19, 2004 | 12:57 AM
ek4hatch's Avatar
Default Re: Just a pic for the turbo guys to cherish (pngfolife)
sick pic
