Turbo Timer wiring question...
Old Jul 19, 2004 | 06:11 AM
skyman88's Avatar
Default Turbo Timer wiring question...
Hey,
I searched first and couldn't find any guide or information for installing a turbo timer in a '92 Civic DX. It's a Blitz FATT DC III. Does anyone know which color ignition and accessary wires to use and if the power source should be a constant or only on with the car being on?
Thanks,
~SKY~
Old Jul 19, 2004 | 08:29 AM
drvfast's Avatar
Default Re: Turbo Timer wiring question... (skyman88)
The ignition wire is a thick white wire which is constant 12 volts. On the blitz harness the red wire connects to that wire. Ignition accessary wire should be a light yellow color, connect the green wire from the turbo timer to that wire. The black with the yellow stripe wire connects to the blue wire on the turbo timer. Then all you have to do is ground the 2 black wires, and the purple wire and you are all set. If you need any more help pm me.
Old Jul 19, 2004 | 11:11 AM
skyman88's Avatar
Default Re: Turbo Timer wiring question... (drvfast)
Hey,
Thanks a lot for the help; I really appreciate it.
~SKY~
Old Jul 19, 2004 | 11:32 AM
DaX's Avatar
DaX
Loved
Community Favorite
Here is how I wired up my HKS Turbo Timer on my Civic:
Grey - E Brake
Brown - 5V RPM Signal
Black - Ground
Red - 12V Constant
Green - 12V Accessory
Blue - 12V Ignition
turbob16a522
Jul 3, 2005 08:49 AM
sporkcrx
Jun 18, 2002 01:28 PM
Hybrid
Mar 19, 2002 12:50 PM
tararan
Dec 26, 2001 09:34 AM
