To Turbo Doctors Help
Old Jul 17, 2004 | 11:46 PM
Endoe0003's Avatar
Default To Turbo Doctors Help
I have a 94 Integra LS BallBearing Turbo...Last week i went to do a compression test here is the result... the first clylinder was at 150- 125- 145- 50..... 50? that does not look good... couple of days later i was driving and by the time i got home... there was oil dripping out of my right headlight... i open the hood and saw oil dripping down from the underside of my hood... i looked all around and notice bits of oil from the BOV... so i pop open the intake and looked inside my throttle there was oil everywhere inside the throttle... i ve taken off the intake and BOV and yes there was oil in the tube...and BOV i cleaned it... what is my problem here...is it because of the compression blow-by or is it because of the turbine oil seal... any ideas...????
Old Jul 18, 2004 | 12:34 AM
pngfolife's Avatar
Default Re: To Turbo Doctors Help (Endoe0003)
If compression is low, you will get excessive blow-by. Check for excessive blow-by by pulling the PCV valve and watching for lots of smoke coming from your valve cover. You may have cracked/melted a piston.
Old Jul 18, 2004 | 07:49 AM
Endoe0003's Avatar
Default Re: To Turbo Doctors Help (pngfolife)
I have not seen it out of my valve cover but from the valve cover breather..... and oil in my sparkplug hole...
Old Jul 18, 2004 | 09:38 AM
Accordt3t4H22's Avatar
when that happend to my car i had to put new pistons, rings and sleaves. Plus clean under the hood it sucked. good luck to you.
Old Jul 18, 2004 | 10:58 PM
pngfolife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endoe0003 &raquo;</TD></TR><TR><TD CLASS="quote">I have not seen it out of my valve cover but from the valve cover breather..... and oil in my sparkplug hole...</TD></TR></TABLE>
That's what I meant, the breather on your valve cover.
Old Jul 18, 2004 | 11:01 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Turbo seals are gone to ****. for sure.
Old Jul 19, 2004 | 07:05 AM
dennis's Avatar
uh, if you're only pulling 50psi out of a cylinder. Probably want to save up for some new pistons... You need to pull the head and see what's going on - or perform a leakdown at the minimum. Either way, I wouldn't be driving on it. Were those numbers off of one cylinder or all 4? I'm confused...
gcrus0120
Feb 17, 2014 12:21 AM
blackeg
Jun 26, 2011 08:53 AM
Accel Junky
Apr 28, 2003 02:18 PM
GruvyTune
Nov 16, 2001 03:54 PM
