Need some help with some boost issues...
Old Jul 19, 2004 | 04:54 PM
SpeedDreamz.com's Avatar
Default Need some help with some boost issues...
Setup.
b18c, 1000cc inj, 9:1 jg motor
Full Race t4t67 turbo kit
tial 40mm .8bar
turbo xs dsbchp
Full race rear fed ic with 2.25 u-bend feeding a 2.5 all the way to the tb.
Here is the problem, I cant get it to make over 20 psi. I have the boost control backed all the way out. THought it might be a fuel issue so I fattened it up with no difference.
ANy help?
Old Jul 19, 2004 | 06:01 PM
Default Re: Need some help with some boost issues... (30psiCiv)
Old Jul 20, 2004 | 04:57 AM
you have gotta be kidding me, is this the forced induction forum? nobody has any ideas?
Old Jul 20, 2004 | 07:25 AM
RacerXI's Avatar
Is it holding boost solid at 20psi or is it fluttering? I'm just thinking your WG spring has met it's limit. Just an idear. btw..howdy from south alabama..
Old Jul 20, 2004 | 07:42 AM
drvfast's Avatar
You need a bigger wastegate spring
Old Jul 20, 2004 | 07:48 AM
B18C1CYA's Avatar
it sounds to me that you have met the limits on your wastegate spring, you can only run 2x it limit, so you must have a 9-10 psi spring
Old Jul 20, 2004 | 09:43 AM
DaX's Avatar
DaX
Loved
Community Favorite
0.8bar spring = 11.6psi. 11.6psi * 2 = 23.2psi. You're very close to doubling your WG spring. Like everyone else said, get a bigger spring.
Old Jul 28, 2004 | 08:02 PM
maxpsi's Avatar
Default Re: Need some help with some boost issues... (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">You need a bigger wastegate spring</TD></TR></TABLE>
I am guessing you already figured this out, Tracy, since you posted about getting a new wastegate spring. I had the same problem after doubling the boost on the wastegate spring. With the new spring, I get better boost response, have to turn the boost controller less, and it takes more stress off the boost controller.
VTi_b0i
Jun 3, 2009 01:50 AM
5l-eater
Oct 20, 2004 03:26 PM
1 POINT 8
Jan 13, 2004 04:16 PM
Spoold_R
May 12, 2003 06:21 PM
Turbo_Teg
Jan 14, 2002 07:35 PM
