code 23 obd1 knock sensor have a question
Old Jul 18, 2004 | 11:42 AM
boosted_dc2's Avatar
Default code 23 obd1 knock sensor have a question
i was cruising down the highway not accelerating of anything and i got this code. i dont think i wasnt detonating either. My question is the knock sensor im using is from an h22 i think the guy said. does it work the same as a b18c1??? because i got this code does it mean it was detonating, of does it mean there is a problem with the sensor???
Landon
Old Jul 18, 2004 | 01:39 PM
Bailhatch's Avatar
Default Re: code 23 obd1 knock sensor have a question (boosted_dc2)
problem with the sensor or wiring. The honda manual has a diagnostic procedure for this, try to find it and run it. On a side note, you did torque it exactly to spec right?
Old Jul 18, 2004 | 01:50 PM
Default Re: code 23 obd1 knock sensor have a question (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">problem with the sensor or wiring. The honda manual has a diagnostic procedure for this, try to find it and run it. On a side note, you did torque it exactly to spec right?</TD></TR></TABLE>
no man, i didnt torque it. ****, id dint think you had to. its going to be a bitch to get a torque wrence in there too. any idea what the spec is??
Landon
Old Jul 18, 2004 | 02:51 PM
ATS*Mark's Avatar
OG triple OG
im having the same problem with mine , mines like 2 months old and it poped again . i dont get why!
Old Jul 18, 2004 | 02:52 PM
ATS*Mark's Avatar
OG triple OG
Default Re: code 23 obd1 knock sensor have a question (Hella_JDM)
oh and ill reset my codes right and it wont pop untill i get on it , do that means its the sensor right?
Old Jul 18, 2004 | 05:22 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
Landon</TD></TR></TABLE>
it's like 22ftlbs I think and yes it does suck if you don't have a small 3/8" wrench. That wouldent set the code but it's most definatly the right way to do it.
I wonder if there is a way to disable the KS without setting the code... humm, what about unchecking the box in uberdata?
Old Jul 18, 2004 | 06:40 PM
well i have hondata and i know i can disable it, but does the motor need it to run under some condtions???
Landon
gtowni3
Sep 10, 2004 11:39 AM
Grip
Jul 13, 2004 08:43 AM
99spanishGT
Mar 26, 2004 12:40 PM
Asahi
Sep 3, 2002 02:41 AM
