Need help rich running turbo but horrible low end torque
Need help rich running turbo but horrible low end torque----------- 4:58 PM 7/17/2004 --------------------------------------------------------------------------------
I need some advice-- i got my turbo finally fixed(with it running extremly lean.) But now it runs rich which is not a bad thing but i get extreme hesitation in first gear-- when i start the car and let it idle in about a min or two it acts like it wants to die. When i try to start off in first gear only getting the rpms to about 1 1/2 i cant go anywhere it will darn near die on me. But if i give it 2 3/4 ( 2,650 rpm range) It will go but then drop right back down like i am stopping then go again. It does it threwout the gears if i am driving normally not alot of gas to get the turbo to spin up. But if i get the turbo to spin up i have no problems. I cange the spark plugs but i knew that wasnt the problem i was just hopeing. It has the be a fuel management issue. I have a 2001 honda civic ex with a *** import turbo. If anyone has any info plz help.
Thank you
spotteddawg
11
02-16-2005 05:55 PM
Kclerk
11
07-19-2004 12:13 PM
OKSolSi
05-07-2002 11:36 PM
