Black smoke when in boost
Old Jul 18, 2004 | 10:56 PM
turtle-eg's Avatar
Default Black smoke when in boost
Does anyone get a small cloud of black smoke when it boost? My A/F is at about 12.0 and everytime I boost, there's black smoke coming from the exhaust. Should I lean it out a bit, if so what should I lean it out to?
Old Jul 18, 2004 | 10:58 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Black smoke when in boost (turtle-eg)
IM RICH BIotch
Leave it were it is. you don't want blue smoke.
Old Jul 18, 2004 | 11:04 PM
B18bEK's Avatar
i wouldn't lean it out anymore. oil? turbo seals? could be alot of things. probably not fuel from running too rich though
Old Jul 19, 2004 | 05:39 AM
mrbsponge's Avatar
my motor is damn near perfect, no oil burning at all, and i get that black puff of smoke under hard boost, it is perfectly normal from all the fuel being dumper in at one time and alll the boost and stress you are doing to your motor, but seriously its better than detonation
Old Jul 19, 2004 | 06:35 AM
slamedturtle's Avatar
Man i get a car sized black cloud out mine in full boost. I guess that is why i dont understand the egt probs. But for real leave it alone. Its not worth the small hp gain you would get to lean it out and risk the motor.
Old Jul 19, 2004 | 07:08 AM
ek9vboi2's Avatar
Leave alone if its tuned already.
Old Jul 19, 2004 | 09:26 AM
4-banging's Avatar
Default Re: Black smoke when in boost (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">IM RICH BIotch
Leave it were it is. you don't want blue smoke.</TD></TR></TABLE>
why is blue bad? I thought white was bad.
Old Jul 19, 2004 | 09:53 AM
b_ron007's Avatar
better to be rich then sorry, for reals!
i like a 11.5:1 to be even safer.
mrbsponge's Avatar
blue and white ARE bad, black is good well better than the others
Old Jul 19, 2004 | 10:05 AM
4-banging's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">blue and white ARE bad, black is good well better than the others</TD></TR></TABLE>
So blue and white mean lean...black is rich
Old Jul 19, 2004 | 10:28 AM
pngfolife's Avatar
Default Re: (4-banging)
Blue and white means your motor/headgasket is probably busted. Black means you are running rich. Running too rich is bad also. Overly-rich mixtures dilute engine oil which causes viscous breakdown and loss of lubrication. It is not advisable to go richer than 11:1 A/F.
Old Jul 19, 2004 | 10:47 AM
4-banging's Avatar
Default Re: (pngfolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pngfolife &raquo;</TD></TR><TR><TD CLASS="quote">Blue and white means your motor/headgasket is probably busted. Black means you are running rich. Running too rich is bad also. Overly-rich mixtures dilute engine oil which causes viscous breakdown and loss of lubrication. It is not advisable to go richer than 11:1 A/F.</TD></TR></TABLE>
thank you sir
Old Jul 19, 2004 | 11:16 AM
vaporboy12's Avatar
just a bit rich thats all
Old Jul 19, 2004 | 01:39 PM
93TurboSi's Avatar
Default Re: (vaporboy12)
even cars that are bone stock will have a small(very small if stock) puff of black smoke when they hit the gas. it's normal. if you were running way way to rich you would feel the engine bog and misfire as well as have the black cloud.
bluish white smoke is oil burning. white smoke is water/coolant and can also be small amount of oil.
Old Jul 19, 2004 | 04:13 PM
shadow103rd's Avatar
Default Re: (ek9vboi2)
Rule of thumb....if its working, dont mess with it.
If your trust the tuner enough to make sure that everything it fine. Just leave it alone
Jon
Old Jul 19, 2004 | 04:39 PM
patdemps's Avatar
Default Re: (shadow103rd)
12:1 is nearly perfect for staying safe. Keep it there.
Old Jul 19, 2004 | 05:48 PM
numba1's Avatar
Default Re: (patdemps)
YES what ever you do just leave it alone. my sh*t went boom from detonation trying to get that last HP.
Old Jul 19, 2004 | 05:56 PM
B18bEK's Avatar
Default Re: (numba1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numba1 &raquo;</TD></TR><TR><TD CLASS="quote">YES what ever you do just leave it alone. my sh*t went boom from detonation trying to get that last HP. </TD></TR></TABLE>
isn't that what its about?
Old Jul 19, 2004 | 09:17 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Black smoke when in boost (4-banging)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging &raquo;</TD></TR><TR><TD CLASS="quote">
why is blue bad? I thought white was bad.</TD></TR></TABLE>
I read someone put Blue means headgasket......that's wrong.
Blue=Rings.......burning oil. Either your turbo seals would be out or rings gone
White=mixture of coolant in the exhuast......blown head gasket.
Old Jul 19, 2004 | 10:28 PM
pngfolife's Avatar
BTW, do you have a cat?
Old Jul 20, 2004 | 11:03 PM
turtle-eg's Avatar
Default Re: Black smoke when in boost (pngfolife)
No cat.. just 2.5" downpipe flared to a 3" exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pngfolife &raquo;</TD></TR><TR><TD CLASS="quote">BTW, do you have a cat?</TD></TR></TABLE>
Old Jul 21, 2004 | 10:31 AM
pngfolife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">No cat.. just 2.5" downpipe flared to a 3" exhaust.
That's why you can see the smoke.
Unjockable
May 14, 2005 08:28 AM
madman604
Oct 15, 2003 07:24 PM
turbo_ef9
Jun 19, 2003 11:08 AM
mracura
Jun 5, 2002 10:21 AM
