Turbo problems, please help
Old Jul 18, 2004 | 06:14 PM
donpeters's Avatar
Default Turbo problems, please help
I finally completed installation on my entire turbo kit. The kit is as follows:
Garrett T3 turbo
Log-style manifold
Vortech BOV
Spearco FMIC
Custom charge pipes
Tial 35mm wastegate
Hondata w/ base map
450cc injectors
Walbro 255lph fuel pump
2.5" downpipe (running open downpipe not connected to the exhaust for now)
I installed everything and started the car up, after a little while listening to it idle, everything sounded fine. So I stepped in and took the rpms up slowly. I got to 4400 and then they just cut off and I can't go any higher. I figured this might because a problem because I wasn't driving. So I took the car for a little drive around the block and when I took it up to 4400 it wouldn't go any higher. As I let off the gas, I hear no sound from my blow off valve. I also do not see any boost on my boost gauge.
I am so confused and have tried searching around, but havn't really found anything. If someone could help me out, that'd be great.
I checked for leaks, had some, but fixed them. I purged the oil to the turbo, not a problem. Everything was done correctly and I can't seem to figure out what the problem is.
Old Jul 18, 2004 | 06:15 PM
B18C1CYA's Avatar
Default Re: Turbo problems, please help (donnie4p)
do you have a cel on?
Old Jul 18, 2004 | 06:24 PM
donpeters's Avatar
Default Re: Turbo problems, please help (B18C1CYA)
Yes, my CEL is on, but I believe that is because I don't have my O2 censors hooked up because I am running off a cut, open downpipe right now until my new one comes in.
Old Jul 18, 2004 | 06:26 PM
B18C1CYA's Avatar
what hondata are you useing ? check and see if the red light is on solid.
Old Jul 19, 2004 | 05:19 AM
donpeters's Avatar
I am using a Hondata Stage 2b unit. The system was sent to me with a base map for now in order to get my car running and then I am going to have it tuned in the near future.
What red light are you talking about?
Some people have told me that my ECU may be in limp mode causing it not to rev.
Old Jul 19, 2004 | 06:14 PM
donpeters's Avatar
Ran through some more check-ups. I unhooked the Hondata and ECU and rehooked everything back up. It works fine now. Finally was able to drive the car for a little while and it seems awesome, although I didn't pound on it hard at all yet, just a little sneak peak I suppose.
I still need to fix some little leaks I have and then it will be good to go. There's also a little oil leak from the turbo where the oil return line goes, but that should be fixed soon.
Thanks for the help.
rice a roni
Oct 21, 2012 10:23 AM
dvtlegend
May 3, 2004 05:12 PM
Realvibez
Jan 8, 2004 07:21 PM
aracer69
Jun 18, 2003 05:55 PM
turbod2000si
Apr 5, 2002 01:47 PM
