check engine only at full boost ::need help!::
Old Jul 16, 2004 | 04:03 PM
hatchedzex's Avatar
Default check engine only at full boost ::need help!::
i just finished my boost project on my z6, when i full boost my CEL comes on and i can no longer rev above 3k, turn the car off and it resets and its fine until i reach full boost again, am i in need of a check valve some where to relive some pressure to a sensor? i put a check valve on my MAP and my car ran like absolutle ****. any kind of bypass?
aim sn slivicslpr
thank you!
Old Jul 16, 2004 | 04:08 PM
Jim Truett's Avatar
Default Re: check engine only at full boost ::need help!:: (hatchedzex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedzex &raquo;</TD></TR><TR><TD CLASS="quote">i put a check valve on my MAP and my car ran like absolutle ****. </TD></TR></TABLE>
Did you have the check valve installed backwards?
Old Jul 16, 2004 | 05:12 PM
hatchedzex's Avatar
Default Re: check engine only at full boost ::need help!:: (Jim Truett)
from the directions on the box i had it right. but then again i may have over looked it. also they are for a fish tank and i ran 2 of them inline.
Old Jul 16, 2004 | 05:21 PM
sneakypete's Avatar
Trying running 3 check valves inline and also a round circular check valve.
Old Jul 16, 2004 | 06:12 PM
ntegls's Avatar
Default Re: check engine only at full boost ::need help!:: (sneakypete)
yep definetely a map code
Old Jul 16, 2004 | 06:53 PM
hatchedzex's Avatar
Default Re: check engine only at full boost ::need help!:: (ntegls)
i got a few check valves, they are inline. but there is no way for the air to vent into the atmophere. did i buy the wrong ones? can someone show me a pic of what im suposed to be using. thanks
Old Jul 16, 2004 | 10:13 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedzex &raquo;</TD></TR><TR><TD CLASS="quote">also they are for a fish tank</TD></TR></TABLE>
I would rather beat my head against a wall until I passed out than deal with that.
I recommend programming your ECU to read boost. That way you could have a properly tuned, well running car. Go here: http://www.pgmfi.org
I have had very good success tuning my car with Crome.
You can also try Uberdata: http://www.ecimulti.org/uberdata/
Old Jul 18, 2004 | 05:47 PM
hatchedzex's Avatar
hahaha 4 check valves and 4 line tees i love it when u can fix your car for under 15 bux
thanks all happy boosting!
Johnny_Rocket
Apr 11, 2005 12:35 AM
93hondaboy
Jan 27, 2005 02:59 PM
wanttorace
Jun 11, 2003 06:55 AM
D-SPEED
Jun 24, 2001 07:24 PM
