Hows this setup for an LS?
Old Jul 19, 2004 | 08:02 PM
JLange's Avatar
Default Hows this setup for an LS?
doing more research
Modified by Johnny_Lange at 8:59 PM 7/20/2004
Old Jul 20, 2004 | 05:15 AM
JLange's Avatar
Default Re: Hows this setup for an LS? (Johnny_Lange)
Old Jul 20, 2004 | 05:42 AM
Smooth-GSR's Avatar
What are you using for engine management??
Old Jul 20, 2004 | 06:23 AM
adseguy's Avatar
Default Re: Hows this setup for an LS? (Smooth-GSR)
Turbo is a little small in my opinion. Go at least with a 60 trim T3. I don't know if you know this, but the SS Autochrome manifold is very weak and tends to crack by a lot of people's experience with it. I have seen people brace them and it seems to be a hit or miss with that. But for $250 you can get a decent log manifold in the classifieds or on e-bay. what about fuel pump? Oil lines? Fuel managment (I am very biased against non-standalone setups). Gauges? Otherwise take your time and read a lot. You are on a good start. Here's a thread with other people's setup's in an LS you can even check mine out although it's not built yet.
Old Jul 20, 2004 | 08:03 AM
JLange's Avatar
Default Re: Hows this setup for an LS? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Turbo is a little small in my opinion. Go at least with a 60 trim T3. I don't know if you know this, but the SS Autochrome manifold is very weak and tends to crack by a lot of people's experience with it. I have seen people brace them and it seems to be a hit or miss with that. But for $250 you can get a decent log manifold in the classifieds or on e-bay. what about fuel pump? Oil lines? Fuel managment (I am very biased against non-standalone setups). Gauges? Otherwise take your time and read a lot. You are on a good start. Here's a thread with other people's setup's in an LS you can even check mine out although it's not built yet. </TD></TR></TABLE>
hondata w/ boost for managment
a 255 fuel pump
just a complete turbo oil line from ht sponsors
would a log manifold out perform the autochrome?
Old Jul 20, 2004 | 08:09 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny_Lange &raquo;</TD></TR><TR><TD CLASS="quote">would a log manifold out perform the autochrome? </TD></TR></TABLE>
It will perform just as good if not better. The advantages to a tubular manifold are basically in the fact that you can run a merge collector, which smooths out the flow when all the exhaust pulses join together which creates less backpressure and more power. The SSautoshit manifold doesn't have a merge collector so you can throw that right out the door, plus the wastegate position leads to boost creep.
My 2cents: Spend about as much power and pick up a rev hard or max rev or whatever manifold you like, get something proven to last a long time.
FWD_BEAST
Oct 11, 2012 03:27 PM
Xathine
Aug 18, 2012 06:53 AM
Domo_Arigato
Jun 20, 2009 09:31 PM
BME1986
May 6, 2005 09:46 PM
VASlowTec
Sep 29, 2003 09:58 AM
