is this turbo too big?
Old Jul 18, 2004 | 06:52 PM
z1p's Avatar
z1p
Default is this turbo too big?
Garret t3/t4
4" inlet. 3" outlet. .70 A/R intake, .84 A/R exhaust
my setup will be stock gsr with skunk intake mani.
sfp mani.
3 inch exhaust
2.5 dp
hondata200b
440s
Old Jul 18, 2004 | 06:53 PM
FOrSfEd's Avatar
Default Re: is this turbo too big? (z1p)
What kinda of power are you looking for right now. It should be straight at around 10 pounds but there will be some lag.
Old Jul 18, 2004 | 06:54 PM
z1p's Avatar
z1p
Default Re: is this turbo too big? (FOrSfEd)
i want to run 10lbs. im aiming around 300hp
Old Jul 18, 2004 | 06:55 PM
B18C1CYA's Avatar
it might be because that will make power higher in the rpm range, do you own the turbo already?
Old Jul 18, 2004 | 07:00 PM
z1p's Avatar
z1p
Default Re: is this turbo too big? (B18C1CYA)
i cant talk on pm cus im new. no i dont have a turbo yet
Old Jul 18, 2004 | 07:02 PM
B18C1CYA's Avatar
ok , i have one that would make your goal for sale, like i said this would be perfect for you . 54 trim .63 ex stage 3 spools quick and makes nice linear power
Old Jul 18, 2004 | 07:05 PM
SpoolnG2's Avatar
that turbo is way to big for only 10psi and and 300hp. why not like a simple 57 trim t3/t4e with a stage 3 wheel and a .60/.63a/r ?? There is really no point in having that big if a turbo if your only gonna run 10psi and stay at the stock rev limit. Just my opinion though.
Old Jul 18, 2004 | 07:41 PM
z1p's Avatar
z1p
Default Re: is this turbo too big? (SpoolnG2)
i asking about this because im getting this turbo new for 350.
Old Jul 18, 2004 | 07:43 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">ok , i have one that would make your goal for sale, like i said this would be perfect for you . 54 trim .63 ex stage 3 spools quick and makes nice linear power</TD></TR></TABLE>
well if you plan on building your motor and want to run more boost then go for it but if no the some like what i have listed will be more suted for your goals.
Old Jul 18, 2004 | 07:44 PM
boosted92's Avatar
That's a straight T4 turbo. T3 exhausts don't come in .84 A/R, .82 is the closest. It's a T4 turbo with a .84 on-center turbine housing. I hope you like full boost at 7000+, because that's what you're getting.
Old Jul 18, 2004 | 07:49 PM
z1p's Avatar
z1p
Default Re: is this turbo too big? (boosted92)
i guess this turbo is not for me. thanks for all the reply.
sharik
Dec 23, 2007 08:15 PM
xtremeness101
Jul 24, 2005 07:47 AM
95lsteg
Feb 8, 2004 03:38 PM
egg
May 2, 2003 04:30 PM
BLKCRX
Apr 23, 2003 01:13 AM
