Headgasket or need of ARP headbolts
my car has been overhaeting lately. I have read about heads lifting due to boost. I started the process of changing the head gasket and had a revelation. What would be some signs that my head was lifting due to boost?? I have a leak from the left side of the head. Nothing too major. I dont have ANY smoking during idle or driving. My oil was nice and clean when I drained it. AND the coolant was a bright green. Would the head lifting cause the engine to overheat. I also had a small leak from teh overflow bottle.....it was past the max level. I am using the stock gasket, stock headbolts. Boosting 7 psi on a D series.
Re: Headgasket or need of ARP headbolts (specv5150)
Try replacing the headbolts first and if it doesn't solve the problem then replace your headgasket. It's easy to swap in the ARP studs in a D series. Just make sure you torque them in the right sequence. Good luck.
Re: Headgasket or need of ARP headbolts (e'sd16)
Yeah I was thinking about doing that....I was going to use them anyway. The only reason I posted up is so I could maybe refrain from pulling the head off. Now that I almost have it off and dont plan on putting the turbo back on, I am just going to chyange the gasket. But if anyone has anymore info feel free to chime. I could use it and peopel who search later may be able to use it
VTgringo
12-20-2003 01:11 PM
b00stedbyFastrax
09-14-2002 09:08 PM
