GE ls/vtec dowel pin location **PICS**
OK I'm in the process of building up my ls/vtec setup, b18a block, b16a head.
Ok I have the golden eagle dowel pins and an OEM P30 (b16) Headgasket, I'm pretty sure I have found the proper location, but from searching around HT people have been saying they go in a defferent way.
I have them in big side down, in the ls block, and the smaller part in the head. Now whats funny is everyone says you have to enlarge the holes on the headgasket, but it fit fine... like I mean perfect. Now the way I have it, everything fits perfect, but I didnt have to touch the headgasket. I even tried my old ls headgasket, and it also slid over the dowel pins perfectly.
Here are some pics....
Re: (vaporboy12)
I don't see why I would have problems down the road with the p30 gasket, I'm just going by this thread..
https://honda-tech.com/zerothread?id=1178220
gem's response is on the second page
Re: (Blackack26)
well i have always used ls gasked for all my personal and customer ls/vtec builds....im in the process of a high hp lsvtec and will be using a p30 gasket, im not worried about it one bit versus the ls gasket!!!!!
Re: (Big Will)
Reading more, it seems like the dowels go on the outside two exhaust head studs, small side in the block....
But.. the only purpose of the dowel pins is to align the head/block, so technically can't they go anywhere?
Re: (Blackack26)
Hey ,have you ever thought about listening to others?
The dowel only fit at both end on the exhaust. The B16 head on both end exhaust side is open to thake the dowel and not the other holes.
Wanna try that and see, then say how it works..
Re: (turbocrx1.6l)
Mine fit on the intake side. Thats where I put them. With a B20 gasket. I have had these dowels since when Z10 first made them so they could be a slight difference.
Re: GE ls/vtec dowel pin location **PICS**
im having conflicting issues with this...i got b20 and hearing alot of diff placement for the dowels...http://www.lightningmotorsports.info...tec/josh_8.gif
i didnt do this i drilled the exhaust holes on the end its a b16 head b20 oem head gasket...PLZ HELP
i did put them on the exhaust side. they did not fit perfectly..and also will not fit in head perfectly w/o doing the same as i did on the block is this safe
Hype-R Stalker
But, if you use the stock LS headgasket you either need to drill out the holes for stock dowel pins in the head.
Use a special Headgasket from a kit, or the dowel pins made smaller on one side.
91integraLSVTEC
11-12-2003 08:00 PM
