MSD Wondow Switch 4 Nitrous - which one?
Old Oct 12, 2005 | 04:24 PM
Tippyman's Avatar
Default MSD Window Switch 4 Nitrous - which one?
There are three swithces - which one do i need to control my nitrous so it doesn't spray during redline? i want it so the nitrous starts at like 4500 and cuts off at like7900 so its out of the motor by the time it is at the 8200 redline. thanx!
link: http://store.summitracing.com/...w=sku
Old Oct 12, 2005 | 04:31 PM
JSPECSIR's Avatar
Default Re: MSD Window Switch 4 Nitrous - which one? (Tippyman98)
msd8956, or msd8969 . $85 and $89 dollars at summit racing.
Old Oct 12, 2005 | 05:36 PM
SFWD 1934's Avatar
Default Re: MSD Window Switch 4 Nitrous - which one? (5THGENSI)
Go with the MSD-8969. It is adjustable from 200-15,000 RPM in increments as small as 100 RPM. It will also save you money as you will not have to fork out and extra $30 for a 5 pack of pills, and you may have to spend more then that to get the desired RPM points you are looking for. The MSD-8969 can just be scrolled through to set the points of on/off RPM.
Jason
Old Oct 12, 2005 | 05:47 PM
raceACCORDingly's Avatar
Default Re: MSD Window Switch 4 Nitrous - which one? (SFWD 1934)
when i ran nitrous i had the old one with the pills kind of a pain but i ran a 3k rpm pill and an adjustable rpm pill. adjustable pill was like 15 bucks and saved alot of money.
BIG T
Feb 26, 2008 12:45 PM
HandoEX
Dec 29, 2006 08:04 AM
Bleed Black
Oct 1, 2002 02:44 PM
H23 Power
Oct 24, 2001 03:46 PM
pstreck
Aug 18, 2001 05:44 PM
