vac lines
Old Oct 14, 2005 | 08:49 PM
teddy_dc2's Avatar
Default vac lines
i'm running all my acesseries: fmu, bov and boost gauge to my fpr. my bov is not going off all the way, is this too much for one vac line?? that other line that looks like a fpr behind the fpr, can i use that for my bov??
Old Oct 14, 2005 | 08:56 PM
adictionbass's Avatar
Default Re: vac lines (teddy_dc2)
yea, thats too much stuff off of one line. Pick another line comming off the manifold and T into it
Old Oct 14, 2005 | 09:03 PM
teddy_dc2's Avatar
i don't really know my lines, will that line that looks like a fpr behind the fpr be fine? too much acess might be the reason why my **** isn't running right
Old Oct 15, 2005 | 09:54 AM
teddy_dc2's Avatar
anyone?
Old Oct 16, 2005 | 11:21 AM
yee SERIOUS's Avatar
for what motor. i'm t'ing all that stuff too off my fpr. HAHAHA but anyways, i got my vac box, just been too busy to mount it and hook it up. i really need though. regardless, you should consider a vac box and T off the brake booster line instead of the fpr. that's what i'm gonna do
Old Oct 16, 2005 | 12:44 PM
Si Shane's Avatar
Default Re: (undercoverdc2)
If you t mulitple actuators/sensors off of one source you will adventually dull the response.
For example, My BOV worked quickest (least compressor surge) t-ed alone off of the brake booster.
Old Oct 16, 2005 | 02:00 PM
Muckman's Avatar
Moderator in Chief
Default Re: (teddy_dc2)
If your going to T everything off one line make sure its at least a big line, like the brake booster.
Old Oct 16, 2005 | 02:38 PM
teddy_dc2's Avatar
i'ma hook the bov to a seperate line but keep the fpr vac line with the fmu and boost gauge. i might have a leak through my boost gauge cause it's a plastic tube that came with it.
Old Oct 17, 2005 | 02:31 AM
did u buy the gauge new? those teflon lines are usually pretty durable.
Old Oct 17, 2005 | 03:50 PM
teddy_dc2's Avatar
brand new autometer and came with the thin white tubing, it seems rather cheap tubing cause it can bend an cause a leak. i hooked the bov to the vac line behind the fpr. still same. i think the problem was a blown valve cover gasket. i see oil around my cover and on the i.m.
Old Oct 17, 2005 | 04:16 PM
N20civicB18's Avatar
wouldnt u rather have the fmu on its own line rather then the bov? personnally id rather have my fp go up asap
Old Oct 17, 2005 | 06:00 PM
teddy_dc2's Avatar
i was thinking about gettin the golden eagle vacuum manifold with six slot to fix my problem. it's like $30 but is it any good? i know i got a leak somewhere.
Old Oct 18, 2005 | 08:27 AM
just get a vaccum box then. i have one. just haven't hooked it up.
mikej94civex
Apr 10, 2010 09:09 AM
seeeya04
Dec 1, 2005 06:40 AM
Andrew 825SM
Oct 24, 2002 07:15 PM
Nfurno
Apr 2, 2002 04:25 PM
SlowB16
Jan 7, 2002 04:04 PM
