Nitrous'ed B18C1
Old Oct 15, 2005 | 08:17 AM
Tippyman's Avatar
Default Nitrous'ed B18C1
I've been reading this thread: https://honda-tech.com/zerothread?id=1402083
and i am suddenly very interested in juicing by b18c1 swapped hatch. i've been looking at these upgrades:
o ZEX Dry Nitrous Kit (# 82011)
-$529.99 (http://www.prostreetonline.com)
o ZEX Hyperformance Spark Plugs (Set of 4)
-$20.37 (http://www.zex.com)
o ZEX Booster Fuel Pump Kit
-$191.20 (http://www.zex.com)
o MSD RPM Activated Window Switch
-$85.88 (http://www.store.summitracing.com)
Do you think that once these items are all installed i will be running a safe and powerful setup? (i'll prolly run a 65 shot) this is my daily driver, i should mention, and reliability is of utmost importance. it needs to run just as good all motor as it does while on the spray. anything else i should consider, or do u think this will run strong as is?
Old Oct 15, 2005 | 12:34 PM
done's Avatar
Default Re: Nitrous'ed B18C1 (Tippyman98)
why a zex kit?? wet or direct shot is better
Old Oct 15, 2005 | 12:45 PM
ProjectDarkBlack's Avatar
Default Re: Nitrous'ed B18C1 (Jordo@KAP)
ditch the plugs and the pump, get NGK`s and a Walboro HP pump for half the price
Old Oct 15, 2005 | 12:47 PM
swoyEKr.'s Avatar
zex wouldn't be my first reccomendation ..
I would go with a standard wet or direct port kit as stated above, there's alot of good kits out there, nx, cold fusion, etc.. harrisspeedworks.com sells alot of nitrous kits and you might want to call them and get an idea about the difference in the kits.
Old Oct 15, 2005 | 04:29 PM
Tippyman's Avatar
UPDATE:
I've decided on this setup based on the reccomendations i've gotten and the depth of my pockets:
-NOS Competition Cheater System. URL > http://prostreetonline.com/buy...tems/
-Walbro Fuel pump. (255 Liters Per Hour - High Pressure)
-MSD RPM Activated Window Switch.
-NGK Plugs.
My only question is, which NGK Plugs should i get? i am gonna use the 75 shot, if that makes a difference.
Modified by Tippyman98 at 6:46 PM 10/15/2005
Old Oct 15, 2005 | 05:47 PM
Tippyman's Avatar
bump
Old Oct 15, 2005 | 07:16 PM
Tippyman's Avatar
ttt. anyone know which NGK plugs are right for my setup? i was on http://store.summitracing.com and saw a whole **** load of plugs! which are right for my "new and improved" nitrous setup?
Old Oct 15, 2005 | 08:12 PM
Tippyman's Avatar
i have no idea what plug to get, sum1 help out an ignition noobie.
Old Oct 15, 2005 | 09:18 PM
Tippyman's Avatar
Default Re: (Tippyman98)
103 views and no one knows anything about whick NGK plugs from http://store.summitracing.com i need? there's like 230 plugs on that site, one of them must be right for my application.
Old Oct 15, 2005 | 10:34 PM
SFWD 1934's Avatar
NGK 5238 or NGK 5820. Also with that system, you can remove the secondary butterfly ports if you wanted to. Otherwise you could go with the NOS-5123 which is just a single nozzle wet kit, and that would aid you in the ease of installation and changing of jets is a little easier. With that plate system, the fuel jet is on one end and the nitrous jet is on the other end. Sometimes making it a bear to get to when the engine is hot.
Jason
Old Oct 16, 2005 | 07:53 AM
Tippyman's Avatar
i looked at the plugs and they appear to be identical. i can find no difference except the serial #. wuts the difference, or does it matter?
http://store.summitracing.com/...earch
this is the NGK 5820. the NGK 5238's description and stats are identical
Old Oct 16, 2005 | 09:12 AM
1700anddroping's Avatar
replied in your other post....
harv
Old Oct 16, 2005 | 09:19 AM
done's Avatar
Default Re: (1700anddroping)
75 shot on a stock motor is going to hurt.
Old Oct 16, 2005 | 09:30 AM
Default Re: (Jordo@KAP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP &raquo;</TD></TR><TR><TD CLASS="quote">75 shot on a stock motor is going to hurt.</TD></TR></TABLE>
then i guess 185 is open heart surgery?
harv
Old Oct 16, 2005 | 10:36 AM
Top Ramen's Avatar
Default actually.....
Not if it is done right. Most nitrous problems stem from lack of knowledge. You can spray a lot more than you would think if it is tuned right and even more if you use a progressive controller. The two biggest issues with nitrous are going lean and the shock from the initial hit. Tuning fixes the first and progressive systems fix the second.
If you have questions about nitrous, ask a redneck - spraying is the pinacle of cracker engineering.
Old Oct 16, 2005 | 06:27 PM
Tippyman's Avatar
its a wet shot thats injected directly into the intake manifold, not the intake pipe so it should be fine if i have enough fuel to back it up.
Old Oct 16, 2005 | 11:31 PM
f1 vtec's Avatar
The zex plugs didnt work to well with my car i would just go Ngk bkr7e-11.
hondateg10
Jan 11, 2010 12:02 PM
RZA24
Jan 2, 2007 02:40 PM
STEV3-O
May 19, 2003 08:12 AM
PROJECThX
Apr 27, 2002 05:45 AM
ImprtTunr
Jan 17, 2002 01:24 AM
