d16y8 turbo ACT clutch 6 spuck?
d16y8 turbo ACT clutch 6puck?
Im in the market for a ACT 6 puck clutch and ran into some clutches for all 99 civics. I want to make sure this is the right clutch for a d16. Here are the descriptions and part number
HC5-HDR6
SKU: 83705500590
This kit includes these components:
H-023 - Heavy Duty Pressure Plate
6P212D - 6 Pad Race Disc
RB820 - Release Bearing
PB1002 - Pilot Bearing
AT20 - Alignment Tool
Torque Capacity: 285 ft/lbs.
This is the heavy duty version, goals are to run 15 psi max at about 220 whp . My clutch gave way so I need a new one. Please confirm.
*I know I spelled it wrong but I fixed it.
HC5-HDR6
SKU: 83705500590
Re: d16y8 turbo ACT clutch 6puck? (BigMoneyP)
well call me at 888 628 3247 dave ext 316
i work for http://www.autopartswarehouse.com
ask for me ill point you in the correct direction and get you a good price
For the setup you speak of don't get the 6 puck especially if it is daily driven. My opinion but I used to have the XTSS and switched to a 6 puck because of my goals, drivability wise the street disc is "easier" to drive for daily driving. Mine isn't daily driven but is driven on weekends mostly. I am sure that will change when the boost gets back on. For you goals, the HDSS is fine and will last a long time...
Re: d16y8 turbo ACT clutch 6puck? (ladysman)
cool, but the part #HC5-HDR6 will fit y8 tranny's right? ACT website says for all 96-00 civic so I just wanted to make sure since the D series tranny's are different than B series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoneyP »</TD></TR><TR><TD CLASS="quote">cool, but the part #HC5-HDR6 will fit y8 tranny's right? ACT website says for all 96-00 civic so I just wanted to make sure since the D series tranny's are different than B series.</TD></TR></TABLE>
all 92-00 are same
id recomend act 50% hdss
or centerforce II 60%
both will work fine id prefer centerforce due to design differences
but it personal preference
all 92-00 are same
Re: d16y8 turbo ACT clutch 6puck? (gotboostedvr6)
cool, i'm getting a really good deal on this clutch that I can't pass up unless the clutch doesn't work with y8 tranny's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">For the setup you speak of don't get the 6 puck especially if it is daily driven. My opinion but I used to have the XTSS and switched to a 6 puck because of my goals, drivability wise the street disc is "easier" to drive for daily driving. Mine isn't daily driven but is driven on weekends mostly. I am sure that will change when the boost gets back on. For you goals, the HDSS is fine and will last a long time...</TD></TR></TABLE>
This man knows whats up! I also started with a xtss and then upgraded to a xtr6 because of my goals, however the xtss is a much nicer clutch.
xtss > hdr6
Dont get a 6puck unless you *really really* need it.
liam
xtss > hdr6
liam
Re: d16y8 turbo ACT clutch 6puck? (liam821)
good info guys, just what I needed... like mentioned before, my friend has this in stock and selling to me for a really good deal. I'll see how it turns out.
NJslvrtypes
Transmission & Drivetrain
10-20-2008 03:14 PM
PrecisionH23a
06-27-2004 01:40 AM
act, centerforce, clutch, clutches, d16y8, d16y8turbo, good, hc5hdg6, hc5xtss, puck, series, stock, street, turbo, turboactcom
