Boost problem
Old Oct 15, 2005 | 05:03 PM
Po0r LiTTle CoUpe's Avatar
Default Boost problem
LS turbo... T3/t4
Tial 38
Just put on a Turbosmart Manual boost controller
Hits 11lbs then creaps back down....
whats the problem?
havent taken a look at it yet... just wanted some ideas
Old Oct 15, 2005 | 06:18 PM
Qwik_XR's Avatar
Default Re: Boost problem (Quick Hatch)
wow.. usually they creep up!
I'd check all your IC plumbing for leaks.. Sounds like when you get into boost, it may begin to leak past a coupling, and starts to drop off sealed boost pressure..
Old Oct 15, 2005 | 06:22 PM
Default Re: Boost problem (Qwik_XR)
yea but it does fine at 7lbs.. dosent creap + or -
Old Oct 15, 2005 | 07:05 PM
Qwik_XR's Avatar
Ok, so between 7 and 11psi, that 4 extra psi could cause a coupler to leak/bleed off boost.
Check all your couplers, clamps, etc.. You really should see if one of your friend's might happen to have a boost leak tester.. With the car off, pressurize the intercooler plumbing and check for leaks.. That'd be my first step, if I were you.
edit: when it 'creeps back down', where does it steady off at, 7psi?
Old Oct 15, 2005 | 10:39 PM
4-5-6-7
anywhere arround there.... now that i came back from being out... the car boost's 13 and then drops to like 4-7
but ima take alook in the moring.
bads2k
Jun 13, 2014 06:07 AM
Hondacivic1995
Apr 17, 2011 04:40 PM
rudebwoy
Mar 17, 2007 12:53 PM
93TurboSi
Oct 16, 2003 06:04 PM
smoothludey2
Feb 25, 2002 02:39 PM
