B Series plugs in a D series Q?
I cant find D series plugs around my area in the heat range that i would like to use. However, i can get the heat range with my ls motor that im looking for. what i wanna know is this: will a b series plug work just the same in a d series engine?
Re: B Series plugs in a D series Q? (eK9aT10pSi)
i need the 2 step colder ones, but NGK doesnt make a #7 in the stock number that the Z6 calls for. its a 95 del sol with a greddy kit.
Re: B Series plugs in a D series Q? (slambedcivic)
ZFR7F-11 doesn't work? I've used that before in my B16.
It should work, the BKR7E's have a shorter nose and strap than the ZFRs.
Re: B Series plugs in a D series Q? (raene)
the zfr7f-11's are in the ls i have, i just wanted to know if they would be okay in the D series
I personally prefer normal coppers. I'm running the same bkr7e-11s that i run in my b18c... that i run in my d16z6 ( i just gap the z6 ones down to 30)
Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">BCPR7ES-11</TD></TR></TABLE>
Use these!
BKR7E will also work fine.
Use these!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">AFAIK ZFR7F-11 is the same ZFR-style plug recommended for a D16Z6, just two heat ranges colder than stock. </TD></TR></TABLE>
There isn't such a thing.....at least there never use to be.
Re: B Series plugs in a D series Q? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">
There isn't such a thing.....at least there never use to be. </TD></TR></TABLE>
Odd... like I said, I used to use these until I found a supply of BKR7E's. Oh well, use the BCP's.
BKR7E's will work fine. In other words the "B series Plug" will work in the D series just the same. Stock number 6097.
Phil
Phil
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">R5671A-7 </TD></TR></TABLE>
Now you have to explain why I always like reading your input on misc topics (transmissions!)
D Tranny Guru
2 steps colder, shorter plug reach and ground strap. Under boost/nitrous useage the long ground strap cannot transfer heat quick enough, ends up become a glow plug.......
Stock......
Champions that ZEXman suggested, notice you can read the ground strap temp range.......
switched to Ford 30# injectors.......
No pics of when I used the 5671's but they burned cleaner and no more melting ground strap.
Stock......
R5672A-7 (I use the -9's 4 steps colder than stock)
have a slightly longer reach intot he chamber and thus allow for better ignition of the chamber mixture. It helped me out with some slight issues I had.
Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">I run ZFR7F-11 on my sohc no problem. I tried finding a 7j-11, but they didn't make them. </TD></TR></TABLE>
lol, it was the 7j-11 that you can't get.. Sorry raene!!
AlfieRoach
07-07-2011 03:19 PM
raidacaipo
05-13-2009 11:38 PM
newBcrxer
05-03-2004 08:46 AM
