How much Psi can my D15b2 handle.
Re: How much Psi can my D15b2 handle. (Muckman)
ya even with a great tune i wouldn't go over 11 psi, ur motor won't last long
it also depends on your turbo size
u can run 11 psi on a t25 and not hurt your motor as bad as 11 psi on a SC61
the bigger turbo's will make more peak power, that can end up blowing up your motor even on a good tune.
i would run 10 psi max with a small t3 if i were you, but if you like lag
run a SC series and 9 psi max
OrangeBoost
04-17-2006 05:03 AM
