I'm looking for some rough dimensions...T3/T4E
Old Oct 14, 2005 | 02:17 PM
*Boostwerks*'s Avatar
Default I'm looking for some rough dimensions...T3/T4E
I am looking for some rough dimensions of the fallowing. If I could get it in INs that would be great.
1. T3 - X and Y cordinates of a T3 inlet flange. I need the INLET part of the flange measured, not the overall dimensions.
2. How long is it from the end of the turbine housing, to the tip of the compressor inlet?
3. What is the largest diameter of the E compressor housing (not including the outlet)?
4. (4 or 5 bolt housing) What is the distance from the center of the turbine inlet to the center of the turbine wheel?
I'm just doing some solid works stuff, and can't seem find the info anywhere. I found sketches of the GT turbos though, but not the regular Ts.
TIA!!!
Bryson
Old Oct 14, 2005 | 02:38 PM
degradated's Avatar
New User
Default Re: I'm looking for some rough dimensions...T3/T4E (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">I am looking for some rough dimensions of the fallowing. If I could get it in INs that would be great.
2/5/16" x 1/7/8"
7.63"
6.88"
About 3.75" if I'm understanding you right.
Old Oct 14, 2005 | 02:44 PM
5thgencivic's Avatar
1=~2.59x1.86"
2=~7.75"
3=~7"
4=Not quite sure what you mean. Depth of wheel in the housing? Or Distance from outside edge of "outlet" to center of wheel?
Old Oct 14, 2005 | 02:50 PM
BlueShadow's Avatar
Default Re: I'm looking for some rough dimensions...T3/T4E (5thgencivic)
http://www.turboneticsinc.com/turbo_dimensions.htm
Old Oct 15, 2005 | 11:00 AM
Thanks guys!!!
Any idea if the turbonetics measurements are "almost" exactly like garret?
And what I mean't by the last question, was basically the horizontal distance from the center of the turbine inlet, to the center of the shaft. (Which shows as 1.75" on the turbonetics T3/T4).
NotAJDMFanBoy
Dec 27, 2010 05:05 AM
boonacka
Jul 11, 2005 10:39 AM
acuracy r
Feb 21, 2005 10:36 PM
bryan305
Sep 12, 2003 08:26 PM
Tinker219
Mar 5, 2003 04:40 AM
