D16A6 with Z6 head and Apexi AX53B60-P18.
Old 10-12-2005, 10:21 AM
Red_ED8's Avatar
Default D16A6 with Z6 head and Apexi AX53B60-P18.
Does anyone have a similar setup as this? I was looking into getting a AX53B60-P18 turbo kit from Apexi to put on my A6 with a Z6 head and was looking for some input on this setup. For now I have stock internals, Skunk2 cams and intake mani, what kind of # can I expect and how much psi do you think I can run?
Thanks for all the input you guys can give me.
Old 10-12-2005, 12:10 PM
Red_ED8's Avatar
Default Re: D16A6 with Z6 head and Apexi AX53B60-P18. (Blue_DX)
bump
Old 10-12-2005, 02:01 PM
rainmanef's Avatar
Well dont expect to run any high amount of boost on that(10 is out of the question) Your compression is going to be in the low to mid 10s and you have a stock bottom end so I wouldnt go over 6-8lbs on that setup but thats just me. Good luck.
shawn
Old 10-12-2005, 02:31 PM
Red_ED8's Avatar
Default Re: (rainmanef)
Ok so with some beefer rods like pg6 and pistons I should be able to run around 10 psi?
Old 10-12-2005, 02:44 PM
Red_ED8's Avatar
Default Re: (rota92)
What engine did you have the apexi kit on? and what mods?
Old 10-12-2005, 02:45 PM
93turbo16's Avatar
with good engine management, I wouldn't be scared to run 10 psi. The kit is pretty sound.
Old 10-12-2005, 02:52 PM
Red_ED8's Avatar
Default Re: (93turbo16)
Well I think thats all the input I need, so thanks alot for the advice guys.
Crazy4Honda
35
12-30-2006 09:01 PM
97grnrs
01-27-2006 06:29 AM
yeah_its_boosted
01-23-2006 12:31 PM
Doug684
05-25-2004 04:45 PM
Quick Reply: D16A6 with Z6 head and Apexi AX53B60-P18.
