adjusting Map Scalars in Uberdata
Old Oct 11, 2005 | 06:38 PM
See Are X's Avatar
Default adjusting Map Scalars in Uberdata
im new to this, how do I change the Map Scalar to run up to 20psi? Just enter in the numbers? like 3.00 - 6.00 - 9.00.....up to 20.00?
Is there any way to add more columns(on the vac/boost side) in the tables to make it more defined for tuning?
Old Oct 11, 2005 | 06:42 PM
non-VTEC's Avatar
Default Re: adjusting Map Scalars in Uberdata (See Are X)
you wont be able to run 20psi unless you change your map sensor. even if you change the values manually uberdata wont save them until you select the proper map sensor.
once you have changed your map sensor you go to the boost tab and select what type of map sensor you have (2bar, 2.5bar, 3bar etc...) once you hit apply all the map scalers will be filled in for you.
Old Oct 11, 2005 | 07:30 PM
See Are X's Avatar
Default Re: adjusting Map Scalars in Uberdata (non-VTEC)
ok, I changed the MAP sensor to a 3 bar. But in the boost portion, it goes "6.20 - 12.61 - 19.01 - 25.42 - 29.40"
Is it safe to just change these numbers in the "Map Scalar" section under the "Misc" tab??
I want the boost portion of the table to be like "3.00 - 6.00 - 9.00 - 12.00 - 15.00 - 18.00"
Old Oct 12, 2005 | 05:51 AM
non-VTEC's Avatar
yes you should be able to do that.
Old Oct 12, 2005 | 08:28 AM
93turbo16's Avatar
I believe you can adjust everything but the end two values.
Old Oct 12, 2005 | 09:48 AM
Civicman86's Avatar
I think he is wanting to add more cloumns not just change the values. Instead of jumping like 8psi between two columns he wants it to only vary 2-3 psi per column
Old Oct 12, 2005 | 09:50 AM
93turbo16's Avatar
Yea you can do that. Just don't change the end values, I did and it worked. But bigwig says not too.
Old Oct 12, 2005 | 08:07 PM
See Are X's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Yea you can do that. Just don't change the end values, I did and it worked. But bigwig says not too.</TD></TR></TABLE>
yea...i thought i read somewhere, that it wasnt safe to change those numbers, and to leave them where they are at?
Old Oct 13, 2005 | 01:16 PM
See Are X's Avatar
ttt
Old Oct 13, 2005 | 01:41 PM
hondaguyef's Avatar
Default Re: (See Are X)
I have never had good luck changing them. I always get crazy outcomes. I leave them be(boost side) and if I need it to read more in/hg I use the "fuel cut value" option in the boost tab. If using the 3 bar enter a number 8 or lower and you'll get up to 26.xx in/hg readings. Just some insight, good luck.
Phil
Old Oct 13, 2005 | 02:42 PM
adseguy's Avatar
Default Re: (hondaguyef)
I did a lengthy writeup on this in the Uberdata forums where this type of question should be anyway .
http://uberdata.pgmfi.org/foru...=3494
YOUR WELCOME...haha
Old Oct 13, 2005 | 04:10 PM
93turbo16's Avatar
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">I did a lengthy writeup on this in the Uberdata forums where this type of question should be anyway .
YOUR WELCOME...haha</TD></TR></TABLE>
viper_boy403
Engine Management and Tuning
Oct 30, 2011 07:30 AM
H-allmotorda9
Feb 7, 2010 07:29 PM
insaneconceptz
Mar 7, 2009 01:08 PM
zman
Jun 15, 2006 07:40 PM
LSVtechnologytur...
Dec 9, 2004 04:26 AM
