gsr or ls/vtec
Old Oct 14, 2005 | 03:46 PM
si0385.'s Avatar
Default gsr or ls/vtec
anybody know what can handle more boost on stock internals an ls/vtec (assume a b16 head) or b18c1.
Old Oct 14, 2005 | 03:58 PM
NJIN BUILDR's Avatar
Default Re: gsr or ls/vtec (turbodreamz0385)
LS/VTEC has lighter duty stock internals but a stock GSR has to high of a compression ratio to boost much.Neither one is a good stock option for much boost.
Glenn
Old Oct 14, 2005 | 04:02 PM
TheShodan's Avatar
Moderator
Default Re: gsr or ls/vtec (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">LS/VTEC has lighter duty stock internals but a stock GSR has to high of a compression ratio to boost much.Neither one is a good stock option for much boost.
Glenn</TD></TR></TABLE>
Both can hold about 270whp or so (don't go by PSI) before things need to be re-enforced. Check out the various kits and setups available for both and look at the options based on what YOU'RE looking for, not just the bandwagon stuff.
Old Oct 14, 2005 | 05:37 PM
rsintegra's Avatar
Default Re: gsr or ls/vtec (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
Both can hold about 270whp or so (don't go by PSI) before things need to be re-enforced. Check out the various kits and setups available for both and look at the options based on what YOU'RE looking for, not just the bandwagon stuff.</TD></TR></TABLE>
He's right...and don't worry so much about high/low compression between the two, you'll realize that boost works well either way...it's all on tuning and your overall goals...once you have that figured out, I'm more than positive you'll know exactly what you need.
Old Oct 14, 2005 | 08:39 PM
a1320addict's Avatar
Default Re: gsr or ls/vtec (rsintegra)
though stock blocks do have power limitations, i do believe, especially based on recent examples, that a big part of running good power on a stock block, reliably, lies in the tuning.
i agree 100% with you mac on the estimated power "threshold" for stock blocks.
but, ive seen some pretty nice numbers being put down on stock blocks, and they are lasting....all in part to tuning.
http://www.evans-tuning.com
lots of 300+ numbers on stock blocks..and like i said, theyre lasting!!!
Joelz-Santana
Mar 11, 2009 04:53 PM
-[uSa]-Defcon_07
Jul 28, 2007 12:23 PM
DriveSlowHomie
Jan 26, 2005 08:59 AM
ragerized
35
May 10, 2004 12:22 PM
doggy-vtec
Sep 9, 2003 01:01 PM
