Which turbo for my setup?
Old Oct 12, 2005 | 08:39 AM
AaronJ's Avatar
Default Which turbo for my setup?
So I am researching for my setup that I plan on getting for my b16 hatch. I am going to put together my own turbo kit. I will be on the stock block, looking for about 260 hp, and then building the block later and looking for 375 or so.
I plan on using a spoolinperformance manifold and downpipe, and a T3/T04e turbo, but I am confused on what trim and AR size and all that **** means. I will be running on pump gas and tunning with either BRE or Hondata. As far as I know I was planning on running a 57 trim with the .63 AR, but I am unsure of how many different measurements their are on a turbo, since some people just say t3/t4 57 trim, or 60 trim, or 63ar hot 50ar cold...I am just confused on what I need for my setup
TIA
Aaron
Old Oct 12, 2005 | 10:51 AM
AaronJ's Avatar
Default Re: Which turbo for my setup? (AaronJ)
Forgot to add, this is a daily driver with occasional trips the the drag strip, so I would like spool time to be decently quick...
Old Oct 12, 2005 | 11:02 AM
turbochargeb18c's Avatar
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ &raquo;</TD></TR><TR><TD CLASS="quote">Forgot to add, this is a daily driver with occasional trips the the drag strip, so I would like spool time to be decently quick...</TD></TR></TABLE>
then get either a .48 a/r or a .63 a/r..the .48 a/r will spool up quicker than the .63 a/r....
.48 a/r = quick spool and mid range power band and little top end
.63 a/r = little lag w/ mid to top end power band(good for street & strip)
.82 a/r = laggy w/ hella top end power band( mostly for drag strip)
so hope this help...
Old Oct 12, 2005 | 11:06 AM
AaronJ's Avatar
so is the "AR" just a measurement of the turbine side of the turbo, or the compressor side? And if so, what is it measuring.
So far I think it will be a T3/To4e 57 trim with .63 AR and stage 3 wheel? does that sound about right?
Old Oct 12, 2005 | 11:09 AM
BANNED
Default Re: (AaronJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ &raquo;</TD></TR><TR><TD CLASS="quote">so is the "AR" just a measurement of the turbine side of the turbo, or the compressor side? And if so, what is it measuring.
So far I think it will be a T3/To4e 57 trim with .63 AR and stage 3 wheel? does that sound about right?</TD></TR></TABLE>
the a/r could be measure on both exhaust and compressor...your turbo sounds good for a street & strip set-up...
Old Oct 12, 2005 | 06:41 PM
AaronJ's Avatar
anyone have any more input?
Old Oct 13, 2005 | 08:45 AM
yee SERIOUS's Avatar
i would say get the .63a/r .57trim. that's what i'm running now. i had the .48a/r .50trim before. my old turbo was great for a quick spool. but the .63a/r just hulls when boost kicks in.
the .63a/r will give you some room to grow too. you won't have to upgrade in a turbo. if you think that is too small, get a t3/60-1
Old Oct 13, 2005 | 09:53 AM
Benjithx's Avatar
Default Re: (undercoverdc2)
GT30R
do it
Old Oct 13, 2005 | 11:51 AM
TheShodan's Avatar
Moderator
Perhaps I can help. Please PM me.
Manny86
Oct 21, 2007 02:13 PM
meagainsttheworld
May 20, 2007 06:40 PM
LSR-Abuser
Oct 21, 2005 12:55 AM
pip9
Dec 18, 2003 03:59 PM
1fstevo
Nov 18, 2001 01:07 AM
