gsr motor, what can I put on the b16?
I just pulled a motor out of a 95 gsr...........The kid blew a hole straight threw the block...........but the rest on the stuff on the motor looks good......Is there anything that I could take off and throw on my B16a that would increase horse/torque...................thanks in advance
Re: gsr motor, what can I put on the b16? (90_Civic_Hatch)
The cylinder head wil yeild higher compression on your block because of the smaller combustion chamber. It also creates a better quench area. Match that up with a skunk intake manifold and your looking at a nice improvement. You could also use his crank with a custom set of rods and pistons to create a 1.8 ltr.
Re: gsr motor, what can I put on the b16? (Tbone)
thanks, that would be better for NA though right (cylinder head)..........I just may get a turbo over the winter, but I am still thinking about it.............Anything else for improvements?
Thanks Tbone
Thanks Tbone
If you're running the stock 1g b16a1 cams..you could swap in the GSR cams, if not the head. It's slightly more aggressive. It's not much, but worth it if it's free.
-Eddie
-Eddie
Re: gsr motor, what can I put on the b16? (EF'n Fast)
definatley for free............its all for free .....woot....
good idea, i didnt think about that......the cams are mine hahahaha.........thanks for suggestion
While you're at it, might as well grab the valve cover too. The valve cover that came on my b16a is ratty and chipped.
You're not stealing this stuff are you?
-Eddie
-Eddie
get the gsr throttle body, is way better than the b16a, only by 1.5mm. but it's a lot though.
Re: gsr motor, what can I put on the b16? (ULTRA911)
definately not steeling it..........I have to replace a motor for someone and I am going to ask him if i can keep some stuff off the old one.............hopefuul I can keep the whole thing.............The throttle body will definatley fit though?? Thanks guys
streetsold6teeny8
19
01-24-2010 05:38 AM
CCCPRB
09-09-2008 06:10 PM
JoHn CoNrOe
06-30-2002 02:41 AM
