b20 in CRX ecu help
b20 in CRX ecu help
im getting a b20b and I am going to be using all of the obd2 components (dizzy alternator and fuel injectors) with rywire conversion harnesses. my question is... can I run an obd1 ecu and if so what ecu would be best to use? im a noob to hondas and any help would be great! Thanks H-T for any help!
Re: b20 in CRX ecu help
Should I use a PR4 with a b20 basemap or will just a stock PR4 do the trick. This is going to be my DD and only plan on adding I/H/E
You should get your self an obd1 ecu and have it tuned. any stock ecu is going to be detuned for a b20 engine. The bigger displacement needs more fuel than an LS ecu will provide not to mention its designed to run with 87 octane, timing and 90+ octane make a big difference in both the b18 and b20. If your going to be adding I/H/E you should definatly have it tuned to see the potential otherwise dont bother. And no you shouldnt drive it on a base map, its a base to start with not a tune to drive with
str8drift
07-12-2008 11:15 PM
