4-Wire oxygen sensor
Old 09-11-2011, 02:02 PM
DRatedA.W.D.'s Avatar
Default 4-Wire oxygen sensor
I'm cleaning up wires and jumper harness wires after previous owner did the mini-me swap but didn't finish completly. Jumper harness, o2 sensor and 3 left over wires not wired into anything.
Now my question is, the o2 sensor has 4 wires. Can anyone tell me how these wires are wired? Thanks.
DRatedA.W.D. is offline
Old 09-11-2011, 05:15 PM
zrickety's Avatar
Default Re: 4-Wire oxygen sensor
2 heater wires, 1 signal wire, 1 ground. what colors do you have?
zrickety is offline
Old 09-11-2011, 05:22 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
The factory wiring is as follows:
White = O2 Signal (D14)
Green/White = O2 Ground (D22 or similar logic ground)
Orange/Black = O2 Heater (A6)
Yellow/Black = O2 Power (A25 or switched +12v source)
OneBadTurboCRV is offline
Old 09-12-2011, 10:58 AM
I got white, green/white, and 2 blacks. Does it matter which black wire gets wired to heater and power?
Old 09-12-2011, 12:27 PM
DO IT ON ALL FOURS
Aftermarket wiring is as follows:
Green = O2 Ground (D22 or similar logic ground)
Obviously it matters - if you get an O2 heater code switch the two black wires around - simple as that.
Old 09-17-2011, 04:51 PM
Magnolialabell's Avatar
I have a 2001 Honda CR-V. My brother pulled off the oxygen sensor without looking to see which wires matched. Love him but Arrrrr! My Honda wires are candy-striped as (1) green/black, (2) yellow/black, (3)white/black, and (4) solid white. I have a Bosch Universal Oxygen Sensor and it has 2 white wires (Heater), one gray wire and one black wire. I would deeply appreciate it if someone could tell me which wire matched to what.
Magnolialabell is offline
Old 09-17-2011, 05:23 PM
You sure you're posting in the right forum for that question?
Old 09-02-2015, 07:01 PM
Gerardomx's Avatar
Bosch Universal Oxygen Sensor.- 2 white wires (Heater & power), one gray wire (ground) and one black wire (signal).
So the you might connect the gray and black first. Start the car and look for AF lamba signal. if ok, now connect one white to one black....and check if you have check engine light?, if not (ok), connect the last white to the last black. If not ok, swap to blacks. good look.
Gerardomx is offline
Old 09-02-2015, 08:25 PM
Former User's Avatar
Old thread locked.
Former User is offline
Tomina
10-14-2014 11:04 AM
91efbluehatch
13
11-07-2012 06:21 AM
underdog51
11-25-2005 12:09 PM
V3locity
07-26-2004 06:54 AM
Quick Reply: 4-Wire oxygen sensor
