Cooling fans issue/questions
Old 05-07-2012, 10:41 PM
FEAR6655's Avatar
Default Cooling fans issue/questions
1988 CRX Si JDM (D16ZC)
So I recently had my outer thermostat housing fall apart from corrosion, so I spent the weekend replacing that as well as the thermostat while I was there for good measure. I also then noticed that the two small hoses on the inner thermostat housing were reversed (heater return and recirculation hose) It was hooked up so that the heater hose was the one that was cut off by the thermostat's foot when open. So I swapped those around (as per the service manual diagrams), put the new thermo in with the new outer housing. I now have good heat and the car doesn't overheat at all idle or highway.
My issue is the cooling fans. They come on at what I presume is the right temp, but after coming on they won't turn off. If I let the car sit for a while eventually the bottom radiator hose (return) goes cold indicating a closed thermostat but the fans will stay on. The only way to get the fans off is to turn the heater onto max. To me this sounds like a bad thermostat. The thermostat I installed was rated at 77 degrees (manual states 78 +/- 2).
Would I be right in starting with a new thermostat (before I put it in I did test it in boiling water along with the old one and it DID seem to open a bit later than the old one, but I just shrugged it off)?
Old 05-07-2012, 11:09 PM
hussain-vtec's Avatar
Default Re: Cooling fans issue/questions
here you go help your self!
link below go for (5. Engine) then (i. Cooling System)
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Good luck
Old 05-08-2012, 12:04 AM
FEAR6655's Avatar
Didn't find any answers in there...
Also, I was wondering if anyone could answer a question about the cooling system, specifically about how the thermostat is located on on the return side of the radiator, as opposed to 100% of other cars I've seen with it on the outlet side. How would that possibly allow the thermostat to regulate the temp?
Old 05-08-2012, 12:36 AM
It supposed to be like the image below the spring side goes in Engine block side.
Old 05-08-2012, 12:49 AM
FEAR6655's Avatar
The themostat is installed correctly; that is the only way the cover could possibly be bolted on. My question was regarding the direction of coolant flow, not the direction of the thermostat.
Old 05-08-2012, 01:41 AM
Do you mean the circle of the water coolant in rad?
IF that so the thermostat hose down side is cold water here the Explain.
Link below
http://www.heal-a-seal.com/TECHNICALINFO.html
Old 05-08-2012, 02:04 AM
FEAR6655's Avatar
Thats the question I have, that image, and every other website plus other cars I've looked at have the thermostat on the engine hot water outlet, whereas on the CRX its on the cold water inlet.
Old 05-08-2012, 02:41 AM
Old 05-08-2012, 04:26 PM
FEAR6655's Avatar
Bump
xolk88
10
03-18-2010 05:18 AM
d16a9_edcivic
13
12-14-2008 11:50 AM
Mavrick
11
11-03-2005 09:10 PM
silvsrt4
10-01-2005 11:23 PM
Quick Reply: Cooling fans issue/questions
