Question about Injectors
so i spun a rod bearing in my Y8 motor well when i was tearing down the motor after i had taken it out of the car, i droped 2 of my injectors on the shop floor and cracked that bottom plastic pice (obd-0 si)... well i picked up a complete D15B vtec yesterday and it came with obd-1 injectors. so my question is can i use these obd-1 injectors since i'm still using the injector resistor box???
Thanks, Isaac-
Modified by 90 Si Hatch at 6:37 PM 6/21/2007
Thanks, Isaac-
Re: Question about Injectors (abnaasefmb)
ur gonna have to get rid of the resistor box and get some obd1 injector clips and wire them in..theres a good article somewhere on the net for this, i will try and find it for u
Re: Question about Injectors (99teggsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr »</TD></TR><TR><TD CLASS="quote">ur gonna have to get rid of the resistor box and get some obd1 injector clips and wire them in..theres a good article somewhere on the net for this, i will try and find it for u </TD></TR></TABLE>
when i bought the D15B it came wtih the cut harness so i have the injectors and the clips....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">its too easy, there is a cap you can get or just solder all the wires that went to the box together</TD></TR></TABLE>
Solder "ALL" the wires that went to the resistor box together?
Re: Question about Injectors (90 Si Hatch)
Yeah hes right about the resistor box, also I'm pretty sure OBD-0 and OBD-1 injector clips are interchangable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">yes he's right! </TD></TR></TABLE>
LoL
LoL
obd1 injectors will work with a obd0 system correctly, if the resistor box is removed. the cap style, is used on all 92-95 civics...
Re: (89_Mangina_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
so where can i get one of these at, i want it looking clean as i can get it!
LOL at the PM in the background with borat.
BTW, the injectors that you dropped, are still usable. the plastic piece you speak of are there to protect the injector tips.
just dont drop them again.
Randysi
04-04-2012 10:17 AM
pinecone
04-25-2006 06:41 AM
