Cam belt change tutorial
Hi,
I'v just got myself a '90 CRX in good shape. I'm just wondering if i should change the cam belt, since it's histoty is unknown.
Does anyone know of a good pictorial on this cam belt change / timing ?
Cheers,
Dave
Cheers,
Dave
Re: Cam belt change tutorial (davelarue)
you mean timing belt? its pretty straight forward take off all the belts off the crank pulley take the crank pulley off take off all the timing belt covers loosen the tensioner support the motor and take off the drivers mount to get the belt off. put it all back together. also when you do it do your water pump too. im sure there write ups on here somewhere just search or get a repair book. the hardest part is usually breaking the crank shaft bolt loose.
Re: Cam belt change tutorial (black0hatch)
Sounds easy hehe. A pictorial would be cool. My crx is just for hobby, i'm not really a mechanic.
anyway, what you said makes sense. I'm attemt this.
Thx!
Dave
Thx!
Dave
sukcak
07-17-2008 07:45 AM
