ef with b16a ignition timing
Re: ef with b16a ignition timing (black0hatch)
same connector as your stock motor, if i'm not mistaken. mine was near the blower under the glovebox. i jumpered it and the CEL came on, so i knew it was jumped...set your timing, turn off the car and remove the jumper...check engine light goes out and you're good to go
CPR
09-16-2001 06:54 PM
