Need wiring help with gsr swap in ef wagon
ok so i have a 89 ef wagon and i just put a b18c1 into it. i did the dpfi to mpfi swap and everything was done right. the problem that im having is that im not getting spark and im not sure why. ive tried 2 ecu's and 2 dizzy's just to make sure and all are known working parts but still no spark. ive tripple checked my wiring and everything is right and i cant figure out why im not getting spark. ive checked all fuses and anything else i could think of so if anyone else has any ideas please let me know. ive searched for hours as well so yes i did search before posting this. thanks
Re: Need wiring help with gsr swap in ef wagon
btw them guys over at www.hondacivicwagon.com know alot
yea it should be pretty fun when its done. and thanks for the website ive never been to that one yet haha ill def check them out.
how are you running the gsr? obd0?
the mpfi, double check all the wires.
add 2 injector clips
all 4 red/black ground wires to resister
c1>b10
c2>b12
c1/c2 to engine
swap dx dizzy plug to Si
c1 is blue/green on dizzy
c2 is blue yellow on dizzy.
injector 2 >A3
injector 4 >A7
swap tps wires
i remember i did a mpfi awhile ago and i forgot the dizzy wires..once thats done it ran
c1>b10
c2>b12
c1/c2 to engine
injector 2 >A3
injector 4 >A7
swap tps wires
yea i got all that done. im running everything obd0. i think i may have figured my problem though. i am using a jdm ef9 engine harness and i just read that the ignitor wire and some other wires in the harness are not pinned the same as on the dx harness? if anyone can verify that i would appreciate it. im gonna wire up the dual point harness tomarrow and hope that everything works. thanks for the help.
the Dx harness? no im sure they are different. use the DX harness and do the mpfi on there. i bet you the car will run.
it would plug and play it the car trim was an Si.
im gonna pull the jdm sir harness off tomarrow and put the dx harness on and wire it all up so hopefuly it will work when im done. i didnt realize that the chassis harnesses were different between dx, hf, si and so on. thanks for the help.
haha yea i love my wagon, cant wait to get it running now! im getting really impatient haha hopefully it will be done tomarrow! im a ef lover and always will be
90Attack
13
10-19-2011 02:56 PM
shervang9
28
03-16-2011 12:00 AM
